Old 09-14-2013, 05:42 PM
rfins rfins is offline
Vehicle: 1999
rfins is on a distinguished road
Default Help...no cruise, no odometer, no speedo....
Odometer is out, so is speedo and cruise doesn't work........
Any ideas on what to look for?
Old 09-14-2013, 06:38 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
A new truck!
What's the background on the failures? Suddenly? Cutting in and out? How long have they been out?
Could be your cluster, could be your PCM, could be something in the cluster.
Old 09-15-2013, 08:02 AM
Vehicle: 1999
A new truck!
Was pretty sudden.....but a few months ago I had some sporadic flashing-working of the speedo and odometer.
Old 03-11-2014, 10:06 PM
Another brick Another brick is offline
Vehicle: 1998 Dodge Ram 2500 Diesel 4x4
Trim Level: Used
Color: Green
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Another brick is on a distinguished road
Just replaced the Variable Speed Sensor on the rear end from an internet source. cured the speedo, odometer, 4 wheel drive, brake warning & ABS lights for about $17.
The cruise control (a problem I had too) was due to broken vacuum line from servo to firewall.
Goode luck
