Old 09-22-2013, 08:01 AM
clemet clemet is offline
Vehicle: 2011 Dodge Ram 1500
clemet is on a distinguished road
Default At whits end, lights dimming.
I have a "small" system in my truck right now that is over wired for what it is. I have 2 amps a 1000w Alpine mono sub pushing 2 12's and a 180wx4 Kenwood pushing the door speakers as for a head unit I am using a Pioneer AppRadio2. The amps are not running at max, and I see the dimming at half volume on the head unit. On a heavy bass line the headlights dim. As for wiring I am using 1/0 power and ground from an Optima blue top to junction blocks. I am using 4ga to connect the Alpine amp to the block, and 8 ga to connect the Kenwood all within the requirements for the amps. I have went as far as adding a 3 farad cap in parallel to the blocks. I have also done the big 3 upgrade with 4ga wire alt to battery, and battery to frame to engine. I have verified all connections are tight and clean and am still getting the dimming. Does anyone know what I should try next to eliminate the issue?
2011 Crew Cab. 4" Superlift kit. 20" Rockstars wrapped in 35x12.50x20 General Grabbers
Old 09-22-2013, 09:51 AM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Bigger alternator because you are pushing the limits of your alternator when you actually "use" the setup you've got here?
Chrome... in moderation.
Old 09-22-2013, 10:36 AM
gcscott's Avatar
gcscott gcscott is offline
Rep:1043
You are out of power and need a high out put alternator. If you do not upgrade the alternator you will burn-up the brushes or worse. Go out and see how hot your alternator gets trying to keep up.
Greg
Old 09-22-2013, 10:55 AM
Which one do you recommend? I was running the same system off a stock 92 Chevrolet alternator with the same setup before I had bought this truck.
Old 09-22-2013, 11:38 AM
Arth's Avatar
Rep:2028
Well first check and see what you have. Secondly these newer trucks have a lot more electronics than older ones so that mind set it worked before won't cut it.
Check to see if there is a bigger alternator from the heavy duties you can get. Otherwise just let your finger tips do the walking and see what you find on the internet.
Old 09-22-2013, 11:40 AM
gcscott's Avatar
Rep:1043
Take your truck to a alternator shop and ask them how to get more amps out of your alternator or if you need a larger output alternator. They can tell you the best way to go.
Greg
