Old 09-14-2013, 07:53 PM
WhiteRamSport13 WhiteRamSport13 is offline
Vehicle: 2013 Dodge ram
WhiteRamSport13 is on a distinguished road
Default Underglow on my ram 13'
ok so I am wanting to try to figure out how I can set up underglow on my truck so when I press the unlock button/lock button/auto start the underglow turns on for a set time like 20 seconds or something then turns on. I know thats asking a lot but anyone know how difficult that is? I live in Canada so I cant drive with underglow.
Old 09-15-2013, 08:28 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
If you just want them to turn on with the remote key fob, follow my post for bed lighting and only connect the relay to the under glow lights instead of bed LED lights. You will also be able to turn them on with the bed light switch under your headlight switch. You may need to use a higher amp fuse, but do not go more than 15 amp fuse with 16 gauge wire.
http://www.ramforumz.com/showthread.php?t=152562
Hope this helps. This is how I would wire for what you want.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
