Extended crank after new parts - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-14-2013, 09:31 PM
blzr1128 blzr1128 is offline
Vehicle: 1996 Dodge Ram
Trim Level: Laramine SLT
blzr1128 is on a distinguished road
Default Extended crank after new parts
Shortly after i bought my truck it started cranking for a long time before it started. I replaced Plugs wires cap and rotor. Today I replaced the fuel pump, problem was still there. What else could it be?
Old 09-16-2013, 10:47 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Could be your CPS. There's other sensors that could come to play.
Old 09-18-2013, 11:49 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
^ I second the CPS^
The Crank Position Sensor is located behind the passengers side head where the block and bell housing meet. It's held in by 2 (8 or 10mm) bolts. It may be dirty or have a rust accumulation on it. Try cleaning it to see if it helps. It operates on a magnetic based signal as the flywheel turns.
Pull the CAI (Cold Air Intake) to get a little better access to it.
