cab noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 09-15-2013, 08:16 AM
tjc3 tjc3 is offline
Vehicle: 2012 big horn
Trim Level: big horn
tjc3 is on a distinguished road
Default cab noise
does anyone get wind noise inside the cab. mine can be heard when truck reaches speeds of 50 +
Old 09-15-2013, 10:19 AM
Asur Asur is offline
Vehicle: .
Rep:4373
No issues here but I have read to check the top seal on the doors some seem to bend out of shape and then cause noise.
Old 09-15-2013, 12:58 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
1yr3mos old Zero wind or cabin noise. I installed the stick on VentVisor's and was hoping no noise issue's.....great product, no noise.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-15-2013, 11:37 PM
balloo balloo is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Club cab
Rep:12
balloo is on a distinguished road
A couple thoughts:
1. Check to be sure your rear slider window is closed. If this is open you will get a lot of noise. Open left or right front window a bit, and noise will be reduced.
2. If you have one front door window open and the back windows closed you will get a lot of noise.
3. When I have the drivers window down a bit, I open the right rear window a bit and this reduces noise.
Good luck.
Old 09-15-2013, 11:40 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
My 11 sure did! Dodge did a rapid response for it and added a foam wedge on the A pillar seal. Could be a poorly aligned door as well.
Big Red my old 2011 Sport
