Old 09-21-2013, 01:44 AM
cdetterer's Avatar
cdetterer cdetterer is offline
Vehicle: 2006 Dodge Ram 3500
Trim Level: SLT Big Horn
Color: Maroon
Rep:42
cdetterer is on a distinguished road
Hey guys just checking in. I unplugged the upstream O2 and it is still spitting and popping. The idle will run at 1000rpm, after being brought to a stop or when started, for about a minute then tone down to an almost seemingly stuttering 500rpm. I havent tore into the intake to change the IAC yet, but thats next on the list I suppose?
Old 09-21-2013, 03:41 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
So, you unplugged the upstream (Bank 1) O2 sensor and nothing changed? That would tell me that that sensor is bad, probably. Not 100%, but if you remove a suspected faulty sensor and nothing changes, then it's probably faulty.
Old 09-21-2013, 02:42 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
^that's safe to say^
However it also indicates a bad 02 sensor since the idle dropped down to around 500.
It honestly sounds like a combination between the 02 and the IAC.
Old 10-01-2013, 03:53 PM
cdetterer's Avatar
Color: Maroon
Rep:42
PROBLEM SOLVED. Changed the upstream O2, and for the sake of this form, Ran it with just a new O2 and solved the back firing issue. I also have changed the Cat Converter for other issues and Now the exhaust sounds much better.
Old 10-01-2013, 04:01 PM
Vehicle: 95
Rep:1776
upstream before the cat. Don't get a cheap one. If you buy a cheap one and then a good one since the cheap one was crap then you still wasted money on the cheap one and had to do it twice.
Glad you got it fixed. What brand did you go with?
Old 10-01-2013, 11:12 PM
Rep:2929
Voonderbar! Thanks for posting the resolution.
Old 10-07-2013, 04:44 PM
cdetterer's Avatar
Color: Maroon
Rep:42
I ended up going Bosch, I think I only paid like $25. well worth it to get it fixed.
