Need help with RES/Uconnect - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 09-15-2013, 03:01 PM
Rooster1948 Rooster1948 is offline
Vehicle: 2012 RAM Big Horn Crew Cab
Rooster1948 is on a distinguished road
Question Need help with RES/Uconnect
I just replaced my RES Base radio with an RES hoping to add Uconnect. I installed the new RES, (purchased from Ebay) This radio came out of a 2012 Challenger. At the same time I installed the Uconnect figuring on getting it programmed at the local dealer. The radio does not turn on, neither does the clock show up. I did not expect the Uconnect to work but did expect the radio to at least turn on.
Question is; will the programming also activate the radio? Or, do I just have a dud radio?
Thank you in advance for any insight.
Old 09-15-2013, 09:57 PM
86SN2001's Avatar
86SN2001 86SN2001 is offline
Vehicle: 2012 Ram Express
86SN2001 is on a distinguished road
Who did you buy it from? I just recently went through buying one and having it be a dud.
It would take forever to start up and once it would get going, a lot of the time there would be audio, but nothing on the screen.
I contacted the seller and they were amazingly helpful and I ended up returning it for a refund.
'12 Ram Express/'86 Ski Nautique 2001/'14 Sea Doo Spark (no details, thread will get deleted. AGAIN)
Old 09-15-2013, 10:28 PM
Rep:2968
The RES that you purchased that came out of a Challenger is a LOW SPEED CAN BUS unit
you have a Dodge Ram within the years 2009 - 2012, they use a High Speed Can Bus radio
see if you can return it
__________________________________________________ _______
if you do buy a used RES high speed unit, the external Uconnect Module may or may not work
i don't know if they also need to be the same Bus Speed
if you get a chance to purchase another High Speed unit, these are all 4th Gen Ram stock radios, from cheapest to the best
there are 2 high speed bus RES 130 radios, do NOT get the one without the Phone hard key button
then there are two 430 high speed radios, RBZ & REN, neither have navigation, but both are set up for the tailgate handle mounted Parkview camera
the next radio is the RHB 430N, it has navigation & the same camera can be used with it
the top of the line stock radios are the RHR & RER 730N, both have Navigation & again use the camera, the do not need the Uconnect external module
another thing to check for is the mounting brackets, some are mounted on the top & bottom
the 4th Gen Rams have the brackets on the sides of the radio
check out this site for more info about the stock radios
http://oemautopartsco.com/collection...igation-radios
this site is for the after market radios that you can install
they are listed as either FIT or Modified FIT
http://www.crutchfield.com/app/car/c...elector=Y&vb=N
Old 09-16-2013, 08:47 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
I was going to post but it appears that GTyankee beat me to it, so I'll just 2nd what he said.
Old 09-21-2013, 06:24 PM
Thanks guys. I was able to return the radio and got an RBZ out of a 2012 RAM. I just installed it and it does power up. Now all I need is the unlock code. The seller is trying to find it for me. I would like a backup option however.
Old 09-23-2013, 11:59 AM
Rep:73
print a copy of your purchase from eBay, go to the dealer and the service mgr will be able to pull the security code.
Old 05-10-2014, 12:08 PM
sixxgunner's Avatar
sixxgunner sixxgunner is offline
Vehicle: 2011 Ram 1500 Big Horn
Color: Brilliant Black Crystal Pearlcoat
Rep:17
sixxgunner is on a distinguished road
Great info! Thanks for the breakdown on these radios.
