Old 09-15-2013, 03:37 PM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
Default 2008 factory backspacing?
Does anyone know what the backspacing is for the 17x8.5 factory wheels on a 2008 Ram 1500? I`ve looked on here as well as the internet and can`t seem to find a straight answer, one site said 4.75 and 5.5. I`ve read that the spindles are different on the 2008 and have less clearance than the 2007. I want to figure out the backspacing I need to run 33x12.5 tires on 20" wheels.
Old 09-15-2013, 04:02 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
4.75" backspacing on all 17 x 8.5" rims on 1500s except the Mega Cab which used 5.75" backspacing.
Here's a backspacing to offset conversion chart to help you as well..
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 09-17-2013, 07:34 AM
hemitrx4's Avatar
Trim Level: TRX4
Is the backspacing different for the factory 20" wheels?
Old 09-17-2013, 02:52 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
I believe so.. I am pretty certain the 4th gens 20's have are different, so I would think they would be too.
IG:@briley59
Team Bully's Performance
Old 09-17-2013, 07:41 PM
LowUFO's Avatar
Rep:1109
Yes, 5.75" on the 20s.
Old 09-18-2013, 12:28 AM
hemitrx4's Avatar
Trim Level: TRX4
Ok, here`s what I don`t understand. I squeezed in my wheelwell and measured the clearance between the sidewall of the tire and the spindle and it`s approx. 3/4" and about the same between the tread and the upper ball joint. So with the factory 20" rims wouldn`t the extra inch of backspacing make the rim almost rub on the spindle. I`m looking at 20x10 rims and I just don`t get how it seems that a bigger rims and more backspacing than my 17" wheels adds up to more clearance for wider tires. Going by my math for 20x10 rims I`d need 4.5" backspacing max for a 12.5" wide tire. I just don`t want to order and get stuck with the wrong wheels.
Old 09-18-2013, 06:01 PM
LowUFO's Avatar
Rep:1109
Yeah, I think most guys run -24 offset or 4.5" backspacing for a ten inch wheel.
