Old 09-16-2013, 10:21 PM
pstern's Avatar
pstern pstern is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Sport Premium
Color: Mineral Gray
Rep:76
pstern will become famous soon enough
Default Rear brake line and ABS wire after 6" RCX lift
I noticed that the ABS wire and the brake line looked like they are all out in the open on the rear after the lift (6" RCX) on my 2010 Sport CC.
When I asked the installer about it and he said he sees this all the time and thought you guys might have suggestions or if I am worrying about nothing.
It looks like if you are riding through bushes and branches the lines and/or wires can get ripped out pretty easily.
Id take a pic and show you what it looks like on my truck if it wasnt already dark out.
Maybe Im worrying about nothing.
Old 09-17-2013, 12:13 PM
pstern's Avatar
Color: Mineral Gray
Rep:76
answering my own question here, but I spoke to Rough Country this morning and they told me that the ABS line should be zip tied to the chassis, but be sure to do it while no weight is on the wheels, so it must be done while on the lift.
Old 09-17-2013, 12:41 PM
Lifted Cummins Fanatic
Rep:1946
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
You seemed to have figured it out. But yes, put it up on a lift and take off a bunch of the fasteners that are hold it on stock and then re-fasten it with zip ties in better locations that will now work with a lift. Just make sure it is out of the way of any moving parts to avoid pinching the wire.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | S&B Intake w/ Scoop
