Old 09-15-2013, 11:54 PM
Twinkeys0816's Avatar
Twinkeys0816 Twinkeys0816 is offline
Vehicle: 2006 Dodge Ram 1500
Twinkeys0816 is on a distinguished road
Default switching to a wider tires
so i want to switch my stock tires (245/70/17) to 285/65/20.
what will be affected on the long run if i do this. like for example will it break my 4x4? will it affect other components? or should i just stick to stock but those tires looks to small for my truck. any inputs and advices will be much appreciated and thank you in advance.
Old 09-16-2013, 08:13 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
thats not that big of a tire at all.
there are guys running 37" tires that are 13.5" wide or wider with no problems.
go for it buddy
Old 09-16-2013, 12:23 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Yup, what gonefishin said above ^^
Your truck will probably be a bit slower off the line and you'll lose a bit of fuel economy because of the increase size and rolling resistance. But it shouldn't be much at all and definitely shouldn't stop you from going for it. A wider, taller tire will look much better!
Old 09-16-2013, 11:09 PM
thank you guys! i really appreciate the input. i will definitely swap those tires to bigger ones! hahaha!!!
Old 09-16-2013, 11:47 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
The only time you have to worry about tire size is if you start to rub, or if they become so heavy your braking isn't up to par with the meat. That size is all too common in the area, so you'll be on the same level as most of the Rams on the roads.
Kurtis
