Old 09-16-2013, 04:15 AM
Fredl Fredl is offline
Vehicle: 1979 Chevrolet Camaro
Fredl is on a distinguished road
Default 2006 Ram1500 3.5" Leveling
I've found a 3.5" leveling kit with front spacer on ebay with 2" rear cast block and sway bar drop.
Will i need longer shocks? Is there anything other I should consider?
Old 09-16-2013, 09:04 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I would consider your CV angles with that 3.5" leveling kit from ebay.
you get what you pay for. max leveling I would ever go on our trucks is 2.5"
Old 09-16-2013, 01:24 PM
brandonjansen's Avatar
brandonjansen brandonjansen is online now
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
What gonefishin said ^^
Typically you don't want to go any higher than 2.5" of lift on the front of a truck without doing a diff/control arm drop. Otherwise your angles will be ridiculous. You probably won't be able to get the front end aligned properly and you will have a terrible shutter in 4wd.
Old 09-16-2013, 11:50 PM
Canadian Hemi Pride's Avatar
Canadian Hemi Pride Canadian Hemi Pride is online now
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
^ These 2 know what they are talking about... 3.5" leveling kit is just gonna cause you problems.
Tow mirrors up for the haters
Old 09-17-2013, 03:28 AM
thank you for your input!
i will definitely rethink my plans
had a look at the bilstein 5100 adjustable shocks: can i use the stock coils or do i new new ones?
i found different part numbers for die 5100 adjustables, which one are the rights for the 3rd gen rams?
Old 09-17-2013, 09:09 AM
Rep:1900
You reuse the spring and the spring seat
Part # 24-186988
Old 09-18-2013, 08:27 PM
IDFWY
Trim Level: SXT 4x4
Rep:2802
You will love the bilstiens.. They are great and improve your ride quality too.
