Old 09-16-2013, 09:59 AM
MN13Laramie's Avatar
MN13Laramie MN13Laramie is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Copperhead
Rep:43
MN13Laramie is on a distinguished road
Default Door Sill Protectors
So there is a lot of exposed paint on the door sill when you open the doors of our trucks. My last vehincle ('02 Toyota Sequoia) had some black stick on thick vinyl protectors (http://www.oempartworld.com/index.ph...god4RgAvg) for this paint? Has anyone seen anything like this for our trucks?
Thanks!
Mike
Mike
2013 1500 - Copperhead
Old 09-16-2013, 10:25 AM
tev9999 tev9999 is offline
Trim Level: Outdoorsman
Color: Maximum Steel
Rep:39
tev9999 is on a distinguished road
Not too worried about the paint, but it looks like my dogs put a small tear in the door seal getting in the back seat. I will have to be careful to protect it with a rug or something when they get in and out.
Old 09-16-2013, 10:49 AM
Big Red 1 Big Red 1 is offline
Vehicle: 2014 Ram
Trim Level: Sport Crew Cab
Rep:20
Big Red 1 is on a distinguished road
Just completed this project; my first mod. There is a product called Marine Mat; I bought mine at Overtons (marine supply). Each sheet is 12"x18" self adhesive with a black textured non slip finish. I sized the front sill protectors at 3.5" x 18" and the rears at 3.5" x 9", and rounded the corners using a washer and razor blade for a flawless appearance. One important reminder; the front sills are about 1/4" narrower at the front (I found this out after installing the drivers side, so I removed it and fabricated another). Due to all the curves in the sills, I started at the bottom and pulled up the backing paper about 1" and worked my way up. When I got to the inside curve, I used a screen roller to make sure it was secure. Another trick is to use wax paper behind the marine mat as you install so it wont stick where it's not supposed to; just pull up on the paper as you press on the mat. Looks awesome, and protects the paint. You can also buy 3M anti slip tape in different widths at the hardware store / Lowes / HD, that comes in three colors; Black, Gray and White. The black is like sandpaper though; the others are not.
Old 09-16-2013, 10:51 AM
Color: Copperhead
Rep:43
I did find this after my post:
http://www.amazon.com/Clear-Universa...&keywords=xpel
The guy who did the paint protector on the front of my truck said he doesn't like to do the door sills because of all the ledges, but for $16 I might give it a try...
Mike
Old 09-16-2013, 10:58 AM
Color: Copperhead
Rep:43
Sounds interesting? Do you have any pictures?
Thanks!
Mike
Mike
Old 09-16-2013, 11:11 AM
Vehicle: 2014 Ram
Rep:20
It will be next to impossible to get all the air bubbles out from under the clear film protector. I tried a test area, as I was going to use the clear originally. By the time you run the squeege over the clear plastic to get all the soapy water out, it is so scratched up (and I did use a rubber one) and you are still left with minute bubbles.
I will try to post some pictures later today. I am a new member and am not sure how to go about it as of yet.
Old 09-16-2013, 11:21 AM
Color: Copperhead
Rep:43
Also, do you have a link to the product on Overton's site? I did a quick search and couldn't find anything?
Thanks!
Mike
Mike
Old 09-16-2013, 11:46 AM
BigDRammer BigDRammer is offline
Vehicle: 2013 Ram 1500 Big Horn CC
Trim Level: Big Horn CC
BigDRammer is on a distinguished road
I was thinking about taking mine to Line-x and seeing if that could spray the door sills. I did it my self in a previous truck with the do it yourself rollon stuff but did not like the texture that it came out, too rough.
Old 09-16-2013, 12:31 PM
Vehicle: 2014 Ram
Rep:20
It was Cabella's; sorry, I got it mixed up. Catalog number CAB-061102-01. It's manufactured by Home Quest, PO Box 366, McHenry IL; phone 815-385-6650. I bought a few sheets a while back to do some custom work on an ATV that I had at the time.
I had used Hurculiner on another truck years ago to do the door sills; it looked okay, but I agree; too much texture. The Marine Mat is perfect; not too much texture, just enough.
Old 09-16-2013, 10:56 PM
Vehicle: 2014 Ram
Rep:20
I tried to upload pictures of the sill protectors, but nothing seems to happen. I'll keep trying.
