Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 09-16-2013, 07:56 PM
dschutz1979 dschutz1979 is offline
Vehicle: 1987 dodge d150
Trim Level: le 150
Color: red and white
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
dschutz1979 is on a distinguished road
Default tires
What is the largest tire I can put on a stock 1987 without rubbing? I just wanna fill up the wheel well.
Old 02-24-2014, 08:58 AM
samsnow samsnow is offline
Vehicle: 1987 Ram 150
Color: red
samsnow is on a distinguished road
I got 31" on my 2wd '87 and tgey fill tge wells nicely but front rub when i turn
Old 02-24-2014, 01:57 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
I run 31 x 10.5 on factory wheels. It looks like a 4x4, but it's 2wd. I think they're 6 inch wide wheels. Much better looking. I only get a rub on the right front tire at max steering deflection when under hard braking or if really bouncing (spirited brake and steer, like hard braking on a main road, then 90 degree turn. All the weight is on the right front). It's much less an issue on the left. Perfectly livable. Doesn't happen in regular driving). Now, those same tires on 8 inch wide wheels, the rubbing is more frequent, but it's still not a big deal, and it looks tuff. However, the wider wheels are even better looking under my 4x4 RC (an '84) so they're under it. With a mild lift it's a non-issue.
