Old 09-17-2013, 12:56 AM
CaptainCurseD9H's Avatar
CaptainCurseD9H CaptainCurseD9H is offline
Vehicle: 2011 Dodge Ram Sport
Trim Level: Sport Crew Cab
Color: Charcoal
CaptainCurseD9H is on a distinguished road
Default Daystar 2.5inch...bumpsteer
Hi guys! I have a question for guys running 2.5 inch spacer lift, do you experiment bumpsteer on your ram?Mine as been realigned 2 time and i still have bumpsteer , its not dangerous but quite annoying when doing off-roading or on rough pavement..Everyting is tight in the front end , tire are 295/70/R17 Toyo MT set at 40 psi.I have made a call to an off-road specialist and they said that im not suppose to have bumpsteer with 2.5 inch daystar lift?Do i need to go to another shop? Thanks!
Old 09-24-2013, 06:36 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
i doubt this is the problem but i would check your ball joints and hub. jack the truck up so the tire is 5" off the ground and take a pry bar or any pipe piece of wood or any other piece of material that you can use to pry. place it under the tire and pull up and release some what rapidly if it makes a clink or has any play typically your ball joints are bad. if its fine then put your hands on the right side and left side of the tire and try shaking it left and right if it makes a clink or there is any play your hub/wheel bearing/ tie rod may need to be looked at. also im not 100% sure what the suspension looks like on our trucks since i have yet to mess with mine but if it has a stearing stabalizer, which im sure it does, you can replace it with something like a procomp es1000.
hope my info helps
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 09-24-2013, 09:11 PM
Trim Level: 1500
Rep:177
i doubt this is the problem but i would check your ball joints and hub. jack the truck up so the tire is 5" off the ground and take a pry bar or any pipe piece of wood or any other piece of material that you can use to pry. place it under the tire and pull up and release some what rapidly if it makes a clink or has any play typically your ball joints are bad. if its fine then put your hands on the right side and left side of the tire and try shaking it left and right if it makes a clink or there is any play your hub/wheel bearing/ tie rod may need to be looked at. also im not 100% sure what the suspension looks like on our trucks since i have yet to mess with mine but if it has a steering stabilizer, which im sure it does, you can replace it with something like a procomp es1000.
hope my info helps
Old 09-24-2013, 11:06 PM
Color: Charcoal
Thanks for the advise, the truck is at the shop right now to check this out,i have a 1500 so i dont have a steering stabilizer, probably next step gonna be shock upgrade
Old 09-25-2013, 02:27 AM
Trim Level: 1500
Rep:177
great let us know what they find
Old 09-26-2013, 04:29 AM
Color: Charcoal
Well truck is back from shop , they found nothing , the front end is tight so im learning toward alignment, gonna get a good one from an off road shop for best result. Good thing i made it to the shop 2 wheel have lost all stick wheight and the other 2 miss the half of them...Truck run better now!
Old 09-27-2013, 08:03 PM
Trim Level: 1500
Rep:177
nice great to hear. a off road shop might be able to better help you since they deal with issues like this more often then a normal shop. id ask them what they think.
