Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 09-17-2013, 01:20 AM
ramalamadingdong ramalamadingdong is offline
ramalamadingdong is on a distinguished road
Default HEadliner Backing Too Thin?
I just removed the sagging headliner in my '96, pulled off the clothe and used a wire brush to remove the foam backing and all that remains is thin fiberglass. I watched some videos on replacing the material but the backing always seems to look stiff, like mine did before I removed the foam. It does not seem like the new material will work very well with a flimsy backing.
Old 09-17-2013, 04:10 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
you should be fine just using 3m adhesive.. I just did mine yesterday and looked to have the same problem... the adhesive spray helps stiffen it back up
Old 09-20-2013, 10:31 AM
Which 3M adhesive did you use?
Old 09-20-2013, 12:39 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If you have a fabric store in your area you can usually fine headliner fabric there. It has the foam attached to it specifically for headliners.
I also use a product called Heads-Up. It's an adhesive made especially for headliners.
Old 09-20-2013, 08:58 PM
Color: Blue
Rep:95
3M Supper 76 Multipurpose Spray Adhesive it is the stuff I have been using for years...
Old 09-30-2013, 11:54 AM
My re-upholstered headliner is flimsy, puckered, wrinkly, ugly. I took the headliner into an upholstery shop and was told that I removed too much foam backing. How is that possible? Would I not need a clean surface for the adhesive to work properly? They said that a scraper should have been used. How can just "some" of that old foam be left on the fiberglass? He made some inquiries and found a new shell but I am not able to afford to spend hundreds more. I have already spent over $40.
I would like to remove the new material and start over. Does anyone have some suggestions on something that I can apply to the backside of the fiberglass to stiffen it before I can apply some new material?
Old 10-07-2013, 07:08 AM
Color: Blue
Rep:95
add more fiberglass.
