Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Place your Ad Here!
Old 09-17-2013, 07:04 AM
TMisch77 TMisch77 is offline
Vehicle: 1997 Dodge Ram 1500
TMisch77 is on a distinguished road
Default Steering Play 3-4" each way...
Hi all, new here and not at all a mechanic... I have about 3-4 inches of play in my steering wheel each way. So first I got a steering stabilizer bar put on and that did not help at all, next I put on a new steering gear which also was no help.. so as of right now I am tired of putting money into it with no result to the main problem I am trying to fix, any ideas? 1997 Dodge RAM 1500 4WD 5.2L. Thanks and let me know if I need to add anything. Also sorry if this has already been posted on another thread, I couldn't find it...
Old 09-17-2013, 07:30 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Have you check the steering linkages for movement or play? Look at the steering box and the shaft from the steering wheel connect? May be a bad flex joint on the shaft
or a bad gear inside the box....
Old 09-17-2013, 11:24 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Check near the steering box for cracks in the frame. Also, have someone turn the wheel while you look for play in the steering. Could be a combination of a few worn parts.
Old 09-19-2013, 03:37 AM
jabba974 jabba974 is offline
Vehicle: 1997 Dodge Ram 2500
Color: Driftwood Satin Metallic
jabba974 is on a distinguished road
If you replaced the gear box (new not JY correct?), then I would lean towards the tie rods needing to be replaced....You may also look at the track bar, it could be worn also and cause the axle to shift when turning...
