Need Help Identifying a CAI - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 09-24-2013, 05:13 PM
Viper15 Viper15 is offline
Vehicle: 2007 dodge ram hemi / 1989 tta
Trim Level: sport
Viper15 is on a distinguished road
I'd rather have the stock air box with a K&N
Drag Racing because Golf only takes one ball !
Old 10-02-2013, 09:02 AM
Signal 20 Signal 20 is offline
Vehicle: 2005 Dodge Ram 2500
Signal 20 is on a distinguished road
I pulled off the whole setup the other day and found alittle bit of built up black oil like reside on the inside of the pipe near the filter. Other than that it was relatively clean inside. I just sold my house in Florida and made alittle bit of money so when I get the check I will be buying the S&B cai (hopefully within the next week). My only concern is missing the whole OEM airbox and parts that I might have to use when I install the S&B intake. Hopefully that wont be a problem or I guess I will have to get creative with the install
Old 10-02-2013, 02:59 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
i have the S&B and it comes with all the parts you need. S&B guys correct me if im wrong, the S&B intake doesnt utilize any of the stock air intake parts. however if i could do it over again i would have got the Vararam intake. the S&B works great i just like the way the Vararam intake looks more then the S&B.
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 10-02-2013, 03:07 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1056
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
That is correct the only part the s&b using off the factory intake is the hose that goes from the vent neck of the oil fill to the intake box, but if you dont have that you can pick up a piece of hose at any local shop that will suffice
Old 10-22-2013, 08:38 AM
I just installed the S&B intake on my truck. The only problem I ran into was I have the HBS leveling kit on my truck and the bolt from the passenger side shock was sticking up about 1.5 inches too high. After 2 hours of messing with the S&B airbox I finally just got irritated and cut 1.5 inches off the top of the shock bolt. After that it fit in there fine.
My only complaint with the S&B intake so far is the rubber coupler for the throttle body was alittle big. I had to really tighten down the clamps to get it to clamp onto the throttle body and I'm pretty sure the rubber boot is crimped alittle. Also the rubber coupler for the tube to the airbox was alittle short and I have about half inch on both sides that are short. I'm sure it will be fine but I still wrapped both sides with duct tape to be sure. I know it sounds bad but I would rather be safe than sorry.
Old 10-22-2013, 08:58 AM
Kamanhart's Avatar
Rep:1056
sweet man! im glad you got one on there you should for sure get some pictures up would love to see it
