Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 09-17-2013, 09:57 PM
MLESa7990's Avatar
MLESa7990 MLESa7990 is offline
Vehicle: 2013 1500 Big Horn
MLESa7990 is on a distinguished road
Default 2013 1500 level or lift?
Hey all.
Bought my truck brand new on August 30th (big horn quad cab) and already have a Rough country 2.5 level kit ready to be put in....after some searching of the forums, it seems that many have issues with a vibration or wobble in the front end due to the leveling kit being installed...can anyone share any sort of experience with this particular kit? Lifts the front 2.5 inches and the rear 1.75 inches. I am considering not even using the leveling kit and instead saving up for a 4 inch lift from rough country or from another company, if anyone has suggestions?
This is my first brand new truck and I am willing to take the time and spend the extra coin to do things right the first time. I definitely don't want to get the kit in, only to have issues.
Does it seem like there are less or no issues when going with a full actual lift kit as opposed to a cheap leveling kit? Or is there a good leveling kit out there that wont mess with front end geometry? Any thoughts or suggestions are greatly appreciated. Thanks!
Old 09-18-2013, 07:22 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you should be fine. Many many guys are running these level kits and rarely report the wobble. Though in most cases its only in 4wd on flat surfaces.
I get a minor vib in 4wd with my bilstein leveling shocks...but it's only noticeable on flat ground...who drives on flat ground with 4wd?
Get the kit...you'll be fine
Old 09-21-2013, 09:40 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
You can't go wrong with the leveling kit. So, it is only a matter of what you prefer.
333 Half the beast
I used to be
