Old 09-17-2013, 11:16 PM
liftedlife4x4 liftedlife4x4 is offline
Vehicle: 2001 dodge ram
Trim Level: off-road edition
Color: brown
liftedlife4x4 is on a distinguished road
Default weird random vibration/grinding
alright so when im driving down the road accelarting sometimes my truck will make a vibrating/grinding noise and i can feel it in the floor wondering if anyone else has experianced this...??? ive replaced all u-joints on the front and rear driveshaft also replaced the driver side u-joint, hub assembaly, and axle seal along with rotors and brakes... i do have 35/12.50/15 tires on it wondering if its a trans prob or hopefully something simple!!! please help!! thanks
Old 09-18-2013, 12:23 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Have you noticed:
1. Is it under acceleration?
2. Is it under deceleration?
3. High or low speeds?
4. Turning or in-line?
5. Is it rhythmic?
6. On an incline?
7. Under braking?
Example: High speed while decelerating. <- that would indicate a rear pinion or low gear oil in the rear...
Old 09-19-2013, 09:14 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Double cardan joint ballsocket? That's what mine was... ( on the rear of the front driveshaft ) driveshaft spline sloppy? Seen that, too, but it's generally all the time. Is it worse in 4wd mode? in turns?
