Old 09-19-2013, 09:55 PM
924mike 924mike is offline
Vehicle: 2000 dodge ram
Color: red
924mike is on a distinguished road
Default Battery drain,NO BUS, Stalling
Hello guys, i joined this forum with some hope i could get some direction. My first post may end up being a novel and i apologize. I own a 2000 ram 2500 4wd 5.9l 360 and i use it mainly to tow my camper with it, it is not a daily driver. My problems started maybe a year ago my transmission started shifting late,wouldnt shift, have to goose it and then let off to get it to shift. then it would go away and shift fine. that brings us to two weeks ago it stalled while driving like you turned off the key. Pulled over to side of road and cranked and cranked and then i saw the "no bus". waited a few minutes and it started up and it died two more times before i made it home. Well its been sitting in my garage for two weeks and 3 different times ive had to charge battery back up,(one year old battery), so last nite i took it to autozone and had it tested and it was fine. So i put a meter on it to check Amp draw and i was getting 0.25 amps on the meter. i decided to leave the battery unhooked for awhile and tonite i put it back in and i put the meter back on it before i even started the truck and got 0.01amps, basically no draw whatsoever. I really dont know where to go from here. Ive heard the ckp, cam sensor, governor sensor on tranny could cause the "no bus". ive cleaned all grounds and the inline fuse and i let the truck run and ive driven a little bit again and now it wont act up so i can check it, no codes either. Sorry it went a little long just trying to give as much info as possible. Looking forward to your replys! Thanks in advance!
Old 09-20-2013, 01:16 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
"No bus" means no communication with the computer. I hate to say it, but if all your grounds and connections are good, I'd start looking in to the computer.
