Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-18-2013, 08:48 AM
holderman19's Avatar
holderman19 holderman19 is offline
Vehicle: 2011 Ram 1500 Sport CC 4x4
Color: Deep Water Blue Pearl
holderman19 is on a distinguished road
Default oil pressure question
2011 hemi sport CC. Stock. Where should the oil pressure gauge be just cruising at 65 mph, cruise set, eco on? Mine is sitting just below the 3/4 line. Truck is 2 months new to me so feedback would be great. thanks
Thanks, Ed
Old 09-18-2013, 09:26 AM
jd69627's Avatar
jd69627 jd69627 is offline
Vehicle: 2011 Dodge Ram 1500
jd69627 is on a distinguished road
That's where mine is. The only time it will go over the 3/4 mark is if I floor it when has not warmed up. Not a good thing to do anyway.
Jba headers, Moe's 87mm Throttle Body, Corsa Catback Exhaust, K&N CAI, 180 Tstat, BT Catch Can,
Old 09-18-2013, 10:10 AM
Thanks for the reply. So i guess that is normal then which is great.
Thanks, Ed
Old 09-18-2013, 11:46 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Yes that sounds about right. If you look at your vehicle info on the EVIC, you should read somewhere around 50-54psi for oil pressure with your needle in the just below 3/4 mark. At idle and warmed up after a long drive like you did, you will probably see oil pressure at 24-26psi with needle just around half or less. I hook up my tuner to verify numbers to be of equal value on pressures and temps.
Old 09-19-2013, 08:24 AM
Thanks Gantman I will check with the EVIC cold and warm just to be sure.
Thanks, Ed
oil pressure
