Need quick answer! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-18-2013, 10:28 AM
BowHunter11's Avatar
BowHunter11 BowHunter11 is offline
Vehicle: 2004 Dodge Ram 2500
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
Rep:68
BowHunter11 will become famous soon enough
Default Need quick answer!
I have a 2008 Ram 1500 with a leveling kit. I currently have 285/65R18 Terra Grapplers on 18x9 wheels with -11 offset. I have new 18x9 Ballistic Jesters with 0 offset on the way and I also ordered 1" thick wheel spacers that had studs in them. I plan on running the same tire and am wondering if the spacer will cause any issues, like rubbing? I have a little bit of knowledge about wheels and tires but curious about this application. Thanks for any help!
Rough Country - Rancho - Nfab - 35x12.50 Atturo - 22x12 Fuel Nutz - Smarty - K&N - Air Dog - 4" Straight Pipe to 6" Tip - Turbo Silencer Ring MIA - Husky Liners - Kenwood - Spyder Lights - 30" Curved LED - Truxedo - Bushwacker Pocket Flares
Old 09-18-2013, 11:06 AM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Well in detail to your current spec of -11mm, your offset is about 1/2" out from wheel center. For your new wheels with a 0" offset, plus your wheel spacer of 25mm(1"), I think you will be alright bud. With your tire wheel combo, your tire width measures at 11.22" and just at 32.5" diameter. Again, I think you might still be able to go lock to lock without any fender well cutting. Pics when you get the new wheels on man!
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 09-18-2013, 11:14 AM
Rep:68
I figured I would be fine but just wanted someone with a little more knowledge to reassure me lol.
Thanks for the quick response and I will definitely post photos after I get them installed, probably in the photos section instead of here.
Old 09-18-2013, 11:28 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Should all be good.. And if there happens to be any rubbing it would just be some minor trimming.. I had to trim mine a bit at the front when I get my tires.. I get a small rub now at the back of the passenger side when reversing at a slight incline with my tires turned sharp right.
IG:@briley59
Old 09-18-2013, 11:36 AM
Rep:68
I have also read that if the studs are longer than the spacer is thick, I will have to shave the studs down. Any experience or knowledge on that? Opinions?
Old 09-18-2013, 02:54 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
That was my first thought when I read your OP. I have read threads on that topic but I can't remember how long the studs are. Even if they are longer than an inch you still may not have an issue. It depends on whether or not your rims are designed in such a way as to have room for any lug that may stick out.
Old 09-19-2013, 01:31 AM
Rep:68
Guess I'll find out soon, my wheels came in today . Just waitin on my spacers now...
