Old 08-31-2013, 07:12 PM
tcl tcl is offline
Vehicle: 2001 ram 2500
tcl is on a distinguished road
Default no heat
Had a mechanic pull dash and replace evaporator on 2001 ram because ac wouldnt work. Ac works now but I have no heat. Worked good before puling dash. Now he wants to replace switch. Why would switch be bad all of a sudden. What else to check. Thanks
Old 09-05-2013, 10:53 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Well, if you don't have coolant gushing in to the cab, then I would say the next thing to check is A) the coolant level and 2) the switch, or the connector to the switch. He may have not got it plugged in correctly or all the way.
