Old 09-18-2013, 05:56 PM
miamidad miamidad is offline
Vehicle: 2012 Ram Express Crew Cab
Trim Level: LSD, TBCG
Rep:54
miamidad will become famous soon enough
Default Question about GROUND for Those with Crew or Quad that installed an Amp
I installed my amp behind the rear bench. I currently have the amp grounded between the floor board and the seat belt bolt. I am getting A LOT of noise when the engine is running. so im pretty sure i need a better ground.
Can you all chime in and tell me where you connected your ground. I am looking for other options.
Thanks
Old 09-18-2013, 06:16 PM
Dave665's Avatar
Dave665 Dave665 is offline
Vehicle: 2012 Dodge Ram 1500 Quad Cab
Trim Level: Sport 4x4
Color: PX8 Black
Dave665 is on a distinguished road
installed mine under center console, did you sand down to bare metal ,check location before using self tapping screw
Old 09-18-2013, 07:02 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I bolted my ground wire to the rear passenger seat support. I used a wire brush to clean the paint off the hole and used a 5/16" X 1" bolt and lock washer. Keep the ground wire as short as possible to help with ground noise. Amp JBL GTO-501EZ is mounted to the rear cab behind the passenger seat.
In the picture the large brown wire on the left is the ground wire and it is about 1' long.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 09-19-2013, 11:55 AM
Rep:54
Greg
so to make sure i understand. you made a whole in the seat bracket and attached the ground to that...or you grounded to the floor board were the seat gets bolted down?
Old 09-19-2013, 05:56 PM
Untamed's Avatar
Untamed Untamed is offline
Color: Grey
Untamed is on a distinguished road
I figured I should of used the big rear seat bolt but just used the small rear seat bolt and works fine.
- 3.75" RC Combo Lift - 20" Zinik Wheels - Mud Grapplers - EGR Rugged Flares - Magnaflow 14" -
- IAFF Local F-160 -
Old 09-20-2013, 12:16 PM
gcscott's Avatar
Rep:1043
There was a hole in the seat support already. I ran a drill bit through it and wire brushed the paint off around the hole. Installed the ground wire under the bolt and used a washer, than a lock washer, and finished with the nut.
Greg
