Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Place your Ad Here!
Old 09-18-2013, 09:04 PM
deep cherry deep cherry is offline
Vehicle: 2013 SLT Bighorn
Trim Level: SLT Bighorn
Color: Deep Cherry Crystal
deep cherry is on a distinguished road
Default Mobil1 M1-210 will it fit the 5.7?
I read a post a while back and the guy said they {m1-210} filter did not fit. I bought a couple ,and now wondering if they will fit the 2013 5.7 with 8 speed? Anyone running them? Thanks Don
Old 09-18-2013, 09:46 PM
Grubrunner's Avatar
Rep:3883
That's the part number that M1 claims will fit.
Grub out!
Old 09-18-2013, 09:53 PM
S.FLRAM
You do realize there is only one way to find out for sure. I say put it on and if it don't have a rather large oil spot in your driveway or you engine light doesn't come on your golden!
P.S If it weren't for people trying new thing's we would still be trying to push a square object uphill!
Old 09-18-2013, 10:28 PM
GEOPYR8's Avatar
GEOPYR8 GEOPYR8 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Express QuadCab 4x4
Color: True Blue Pearl
Rep:44
GEOPYR8 is on a distinguished road
It fit mine perfectly and it has almost twice the capacity of the original.
That's my storie & I'm stickin to it!
Old 09-19-2013, 02:13 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Match the BASE and size
When you take your old filter off, put the 210 filter directly against the filter O-ring on your current filter. The rubber gasket size MUST match EXACTLY. It'll be a messy affair so wear gloves over a garbage can.
The diameter, width and height of the filter can be a bit different, but the rubber gasket is what seals the filter on the engine.
The thread and pitch will allow the filter to perfectly spin on to the engine, but the snug fit of the gasket is what matters.
Don't do the puddle of oil on your driveway test.
Old 09-19-2013, 06:47 AM
Talking oil filter
S.flram,did you have a personnel experience?
Old 09-19-2013, 07:20 AM
13Laramie 13Laramie is offline
Vehicle: 2013 Laramie Crew Cab
Trim Level: Laramie Crew Cab
13Laramie is on a distinguished road
I tried it. No luck for me. I have a 2013 1500 5.7 with the 8 speed. Mobil 1 part number is M1-113 and fits like OEM. Go to any auto parts store with the number printed on the stock oil filter and have them cross reference. It will show the M1-113 as well.
Old 09-19-2013, 09:18 AM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Trim Level: Laramie Longhorn
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
The factory installed filter is smaller capacity wise compared to the model that is listed bu all manufacturers (Mobile, RP, Purolatar). This has been discussed a few times and most don't seem to have a problem. I myself just did an oil change this past weekend and replaced the factory filter with a larger, designated Royal Purple filter. They will fit.
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 09-20-2013, 01:18 AM
Trim Level: RT
Rep:136
Default Firemarshall give the part#
To make things simple - what Royal purple oil filter part # did you find.
As I mentioned before, you'll find the RP filter keeps the oil really clean.
Old 09-20-2013, 08:02 AM
Vehicle: 2013
Per RP site,
Recommended filter:
20-820
I searched it while standing in front of the filters aisle in Pep Boys.
Add-ons:
