Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 09-19-2013, 10:49 AM
turbohawk's Avatar
turbohawk turbohawk is offline
Vehicle: 2013 1500 4x4 5.7 6spd
Trim Level: Express QC 6'4" bed
Color: Polar White
Rep:44
turbohawk is on a distinguished road
Default Just passed 8000 miles, noticing engine losing 1/2 qt of oil ever 4k
I had the first oil change done "early" as the dealer kept telling me "change it when the EVIC says", but I changed it "early" anyways...wished I had changed it at 1000 or less like I usually do with new motors. So this first oil changed ending up being at just over 4000 miles, and when I checked the oil (I always check fluids at each fuel stop) noticed 1/2 quart low just prior to the first change. Now, I'm at 8200 and have the exact same 1/2 quart low on the dipstick. Is this normal for this motor? No leaks noted so I guess it's thinking it's a diesel?
I'm spoiled very badly with my Jap trucks (cars and bikes too) never, EVER needing a drop of oil between changes, no matter the interval. My wife's Cadillac burns/leaks a quart of oil every month or every 2 tanks, whichever comes first. It's now being recycled.
Old 09-19-2013, 11:10 AM
dparise's Avatar
dparise dparise is offline
Trim Level: ST w/SXT pkg
Color: Black Gold Metalic
dparise is on a distinguished road
I haven't done an oil change on my pentastar yet, i'm at roughly 8500kms. I noticed the oil was getting a little low at my last fuel fill. I think its normal to consume a little bit of oil, how much of it is "acceptable" and when is it a "problem" is the question I suppose.
Old 09-19-2013, 12:39 PM
Trackstand's Avatar
Trackstand Trackstand is offline
Vehicle: 2013 Ram 2500 CC LB 4X4
Rep:73
Trackstand will become famous soon enough
A new auto should burn close to zero oil, if it was mine it would be dealer bound.
Old 09-19-2013, 07:10 PM
On The Road's Avatar
On The Road On The Road is offline
Vehicle: 2013 1500QC Hemi 4x4 8Spd 3.55
Trim Level: Laramie Frost Beige
Color: Maximum Steel Metallic
Rep:21
On The Road is on a distinguished road
This is my first Ram & Hemi. When I was researching the Hemi one thing that kept coming up was the need for a "Catch Can" for the line from the PCV valve to the throttle body.
I put one on and check it every thousand miles or so. It has a good 1-2oz of oil in it.
From my experience it's not burning it in the cylinder via bad rings etc. It the crank pressure and the vacuum they have set up on the Hemi. The catch can keep the intake and heads from being gummed up.
I just had my first oil change so at 5200 miles so well see if it remains the same or improves as certainly the engine is starting to break in.
RAM 1500 Laramine QC 4X4 Hemi - 8 Spd ZF 8HP70-3.21 -Stainless Steel Door Sill Protectors-Billet Catch Can-Cabin Air Filter Mod -Air Spring 1000's - EGR Hood Shield - TruXudo Lo Pro QT Tonneau Cover-AMP Research Bed Step-DeeZee Bed Rug- Tail Gate Protector-Trimax Spare Tire Lock
Old 09-19-2013, 07:57 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
It sounds like a lot to me, I too would be having a conversation with your dealer.
Old 09-19-2013, 11:23 PM
20hemi10 20hemi10 is offline
Vehicle: 2014 Ram 1500 4x4
Trim Level: Outdoorsman
Rep:14
20hemi10 is on a distinguished road
This is straight from Chrysler.
Oil Consumption- The accepted rate of oil consumption for engines used in the vehicles listed above is 0.946 liter (1 qt.) in 3,200 km (2,000 mi) for the 1st 80,467 km (50,000 mi). For vehicles with more then 80,467 km (50,000 mi) the acceptable oil consumption for engines is 0.946 liter (1 qt.) in 1,207 km (750 mi).
2014 Ram 1500 Outdoorsman 4x4 5.7L
Old 09-20-2013, 01:04 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default There's nothing wrong with your engine
It's the oil you're using. You may need to experiment with a different brand, viscosity, weight, synthetic or filter.
The truck doesn't "think it's a diesel, hybrid or natural gas" as some Freudian confusion.
What oil are you using? Be specific about the brand and weight.
Old 09-20-2013, 03:10 PM
rambill rambill is offline
Vehicle: 2013 Dodge Ram 1500 QC
Color: silver
Rep:40
rambill is on a distinguished road
May be from Chrysler but it is unacceptable and unreasonable to me.
Old 09-20-2013, 05:17 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Oil consumption on the Hemi Engine is normal during the break in period, depending on how you use your truck and if you tow will determine how the engine will break in and how long it will take, usually between 3k - 6k you will burn approximately 1/2 a quart of oil, some have indicated that it takes up to 10k for the oil consumption to slow down, people who tow allot with there trucks say they will burn more oil due to towing, usually around 1/2 quart for every 3k. Even the owners manual indicates that during the break in period "3k" expect oil consumption. Apparently this is something the Hemi Engine is known for, you will read this same information for Jeep, challanger, etc.
Old 09-20-2013, 05:40 PM
chrisb38002's Avatar
chrisb38002 chrisb38002 is offline
Trim Level: R/T
Rep:86
chrisb38002 will become famous soon enough
Where I live, things that burn 1 quart of oil every 750 miles are called "mosquito foggers".
My 03 burned maybe 1/4 of a quart in 5000 miles, that's with almost 90K miles on it. My 13 has close to 2000 miles, and the stick still shows full.
What type and viscocity of oil are you using?
2013 White Ram R/T
Mods: BT Catch Can (red), Mufflex DOD24, S&B CAI, BakFlip VP Tonneau, McGaughy's 2/4 Deluxe, Spohn Adjustable Panhard, AirLift 1000, Hellwig Rear SB.
