Old 09-19-2013, 03:35 PM
robbiele's Avatar
robbiele robbiele is offline
Vehicle: 2013 Longhorn 1500
Trim Level: longhorn
Color: Black Gold Pearlcoat
robbiele is on a distinguished road
Default Noise in steering wheel when turning
Just got my 1500 and there is some noise sounding like something needs to be greased when turning? It is not anything very loud just sounds like something is rubbing or needs to be greased. Is this normal and is anybody else hearing same?
Old 09-19-2013, 04:21 PM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
I got the same thing, only when turning it counterclockwise. i might spray something in between the steering wheel components.
Old 09-19-2013, 04:46 PM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is online now
Vehicle: 2013
Trim Level: Laramie Longhorn
firemarshallvin is on a distinguished road
it's not the steering wheel or the components, it's the tire rubbing on the inner fender well liner. Do you both have the air suspension? This is a known issue, not always present, but there, and there has yet to be a cure found to date. Sorry. On the plus side, at least now you can sleep at night knowing that there isn't anything "wrong" with your rigs! LOL
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 09-19-2013, 04:57 PM
Scott H Scott H is offline
Vehicle: 2014 Ram 1500
Color: Maximum Steel
Rep:12
Scott H is on a distinguished road
Mine does it too.
I read elsewhere on the forum that it is possibly the clock spring in the steering column. That or some of the the wires running through it were not installed properly, causing the scraping sound.
I plan to take it in to the service dept.
Old 09-19-2013, 05:27 PM
robbiele's Avatar
I don't have the air suspension and it is definitely not the tire rubbing but I do still appreciate the info
Old 09-19-2013, 05:28 PM
robbiele's Avatar
Originally Posted by Scott H View Post
Mine does it too.
This sounds like it could be my problem and I will take mine to service dept. as well. Thanks
Old 09-19-2013, 10:36 PM
Omac's Avatar
Omac Omac is offline
Vehicle: 2013 RAM 1500
Rep:29
Omac is on a distinguished road
Mine made the sound then the service airbag system display come on the evic after 800 miles. It was the clock spring. after it was replaced no more sound. My truck was built in June 2013 Its probably a bad batch of clock springs.
Mopar Hood Deflector, Mopar Mud Flaps Front/Rear, Fire/Ice Mud Flap LEDs, Tonno Bed Cover, Mopar Bed Mat, Mopar Tailgate Liner,Window Tint, Husky WeatherBeater Floor Liner Front/Rear, Mopar Chrome Gas Door
Old 09-19-2013, 11:25 PM
kmm316 kmm316 is offline
Color: Jazz Blue Pearlcoat
kmm316 is on a distinguished road
Mine makes the same noise. It is certainly the clock spring as my 2009 challenger R/T had the same problem. Had the clock spring changed out and no more noise. I will be having this fixed during my next oil change.
Old 09-20-2013, 08:58 AM
Vehicle: 2013
Sorry, I tried... good luck with the journey to the dealer.
Add-ons:
Old 09-26-2013, 01:28 PM
MACH MACH is offline
Vehicle: 2014 Ram 1500 Sport CC 6'4"
MACH is on a distinguished road
I had the same thing on my 2013 Laramie. Sounded like a clicking noise when I turned the wheel.
They replaced the clock spring and I haven't had a problem since.
