Old 09-20-2013, 11:36 AM
will36 will36 is offline
Vehicle: 2010 R/T RAM
Trim Level: R/T
Color: BLUE
Rep:274
will36 is a jewel in the roughwill36 is a jewel in the roughwill36 is a jewel in the rough
Default so your ram over heats while towing
2500 4x4 turbo diesel with a ATK ?? aftermarket trans.
We took a thick rubber drawer liner for a tool box used washers and rivets to secure it to the inside lip of the lower spoiler . Its cut the width of the frame. Then you use washers and plastic rivets to secure it to the bottom of the fan shroud. That way if you need to remove the shroud you can just use a razor knife to cut the heads off the plastic rivets.
then use a hole saw to drill a few air vents. this not only allows air to rush in . It seals off that big gap and directs more air pulled in by the fan to come thru all 4 coolers.
We also sealed the top the same way now the fan is pulling air straight thru and not from the top or bottom.
Just did this last night and it helped a lot. We will find out tomorrow going to pick up 2000 pounds of corn.
No I didn't drill the holes........While I was looking for a tape measure the owner (my boss) started eyeballin' it.;(
Old 09-20-2013, 05:21 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Thats interesting, my Ram 1500 never overheats towing my 32' fifth wheel, but my nephew has had fits with his GMC 3500's with 6.0 gas motors towing a slightly smaller trailer.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 215,000 miles To Hell and back. 14.2/96 mph NEDW
