Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 09-21-2013, 04:01 PM
muddy53 muddy53 is offline
Vehicle: 2011 Dodge Ram 5.7L Hemi
Rep:34
muddy53 is on a distinguished road
Default Debadging Help Needed
Trying to debadge my 1500.
First tried some heat and fishing line, no problem their. They come right off.
The problem is getting the residual adhesive off.
Tried using Goo Off. Softened the top layer but didn’t touch the sticky layer close
to the paint. Took me a couple hours to do get ( RAM1 ) off. The Goo Off will not get the residual adhesive off. So I went to the parts store and bought a can of 3M adhesive remover. It also softened the top layer of adhesive but didn’t touch the layer close to the paint. The 3M product does remove the residual adhesive left behind after peeling, rolling and picking the majority of the **** off.
Any suggestions? I’ve still got the other side to do and not looking forward to it.
Heat doesn’t seem to help.
How would a body shop do it?
Anyone have a better product or procedure to try.
Thanx!!
Old 09-21-2013, 04:33 PM
johnnysart's Avatar
johnnysart johnnysart is offline
Rep:122
johnnysart will become famous soon enoughjohnnysart will become famous soon enough
I used the fishing line and some rubbing alcohol and just kept peeling it with my fingers which took a few hours. For me it took some time not easy but well worth it.
Old 09-21-2013, 04:50 PM
Asur Asur is offline
Vehicle: .
Rep:4373
get yourself a 3m double sided foam adhesive remover wheel
http://solutions.3m.com/wps/portal/3...gl865F9HLJ3Kbl
Old 09-21-2013, 04:55 PM
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
Theres also a soft rubber wheel for a drill. Body shops use them for stuff like that or pinstripes. Thats what my dad used for debadging mine
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 09-21-2013, 05:06 PM
bowieknife's Avatar
bowieknife bowieknife is offline
Vehicle: 2013 Sport CC, 5.7L, 8spd
Trim Level: Sport Crew Cab
Rep:71
bowieknife will become famous soon enough
Send a message via Yahoo to bowieknife
Hey Man, I just did mine 3 weeks ago and also did my 2011. You need to use "GOOF OFF". that is the one that works. There is Goo-gone, Crud kutter, blah, blah blah. None of those work.
I squirted goof off on a rag (liberally), and rubbed the spot for less that 45 seconds and it was all gone. Promptly wash with soap and wax immediately when that dries and you're good to go.
Not sure if you had a typ=O on your post but Goo Off sounds like a knockoff. I got the Goof Off at Home Depot in a flip small flip top can.
If you did try the actual goof off, the Maguires Wheel on a drill is the next step.
Old 09-21-2013, 05:09 PM
bowieknife's Avatar
Rep:71
Here is a link on how to properly take off the tape. This worked really well for me...
Old 09-21-2013, 08:26 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I used a pinstripe remover wheel...cost about $15 at Lordco. Worked like a hot damn!
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 09-21-2013, 08:37 PM
Stump3r's Avatar
Stump3r Stump3r is online now
Rep:1266
^^^^What he said! I tried removing like the video above and said screw it and got the wheel!
Big Red my old 2011 Sport
Old 09-22-2013, 03:29 PM
Rep:34
Thanks all for the advice!!
Old 09-22-2013, 03:36 PM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
Credit Card with some 3M remover and patience did it for me after the fishing line.
It was a hopeless feeling before i whipped out the CC!!
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
