Tire size question. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-21-2013, 11:07 PM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
Default Tire size question.
Im buying new tires in a couple weeks. I have a 98 1500 4x4 with a 3" leveling kit. Im trying to figure out the biggest tire size I can go, I would like 35's, or 33's if they will fit.
Old 09-23-2013, 08:20 PM
Nck's Avatar
Nck Nck is offline
Rep:74
Any advice? Guess I could find a mechanic if no one knows about this.
Old 09-24-2013, 11:31 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
Need more info. Wheel size and offset? Without knowing this info, you should be fine w 33s but 35s will depend on how wide your wheels are and how far out they will sit...
295/60r20 Toyo Open Country AT Xtremes (previous tires were 285/65/20 BFG TA KO2s for 75k klms), Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 09-25-2013, 05:07 AM
Nck's Avatar
Nck Nck is offline
Rep:74
They are 16x7's, with an offset of 0.00 mm, I'm pretty sure that's right.
I guess I should have put that info in, my bad.
Old 09-25-2013, 04:08 PM
LowUFO's Avatar
Rep:1125
No worries. I think you need to stick to 33s for a couple reasons. One, putting 35s on a 7" wide rim can be done. But most reputable shops don't like to do it. Two, 35s on that same size rim will feel horrible at highway speed because of the extra flex in the sidewall. Three, they will rub at full lock. Stick to a 33x 10.5 and you shouldn't have any rubbing. If you go to a 11.50 inch wide tire on that same rim, you might rub at full lock or while flexed. But not enough to really worry about.
At the end of the day, there are a ton of different opinions on what rubs and what doesn't and at least as many variables to consider. But when spending money, err on the side of caution and worse comes to worst, you might have to sell them and buy slightly smaller. Not the end of the world. Just annoying.
Old 09-28-2013, 04:19 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I appreciate the help. I think I will go with 33's. But I was also thinking, if I put spacers on, would that allow me to go a bit wider? like the 33x11.5 without rubbing.
Old 09-28-2013, 06:50 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
LowUFO is right on target. Stick with the 33x 10.5 and you won't have problems. I have one. R...
Old 10-04-2013, 04:27 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I appreciate all of the advice guys. I've decided to go with the 33x10.5's. I'll put up some pics once I get them on Saturday.
Old 10-10-2013, 01:36 AM
Nck's Avatar
Nck Nck is offline
Rep:74
I got my tires Yesterday. They are 305/70/16's. Much larger than my old 265's. They don't rub to much at all either. I will put up the pics soon.
Old 10-11-2013, 10:50 PM
LowUFO's Avatar
Rep:1125
So a 33 x 12 basically. And you get a little rub? So a 295 x 75 would have been half inch narrower and still would have been a 33. That would have given you a quarter inch more room on the inside. Lets see those pics!
