Old 10-19-2013, 01:37 PM
Stoneface's Avatar
Stoneface Stoneface is offline
Vehicle: 2013 Ram
Trim Level: 1500 Limited 4x4
Stoneface is on a distinguished road
Default Is This Noise Normal For A Ram 1500
My Ram 1500 makes noise when making a sharp LEFT turn into a parking space. It happens half way into the turn. Doesn't happen when turning right. Only happens if the truck is moving. It has done this since it was new. It happens in 2 wheel drive, I haven't checked if it happens in 4x4 mode. I know some vehicles make a noise when turning the steeling wheel too far, but this seems to happens only half way into the turn. Any suggestions.
2013 Ram Limited
Add Ons: Mopar Tonneau; Mopar Bed Mat & Tailgate Cover; Window Tint
Old 10-19-2013, 02:42 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Vehicle: 2013 Ram1500 4x4 8HP70 3.21LSD
Trim Level: Lone Star Quad Cab
Rep:616
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
If its what I think it is, you must have air suspension. There have been a couple threads on this issue, including fixes for it. You can find them with the search feature.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
Old 10-19-2013, 02:48 PM
Stoneface's Avatar
Vehicle: 2013 Ram
I do have air suspension. I'll do the search to find the fix. Thanks.
2013 Ram Limited
Old 10-19-2013, 05:22 PM
Rep:616
Yeah sorry I wasn't more detailed, but I don't have air suspension myself so I didn't want to give you bad info. Its the tire rubbing the wheel well liner.
Old 10-20-2013, 07:58 PM
Stoneface's Avatar
Vehicle: 2013 Ram
Your are right. It was the tire rubbing the wheel well on the driver's side. After a little re-engineering, problem solved. This Forum is better than any service department in the country. Thanks again for your help.
2013 Ram Limited
