Old 09-22-2013, 09:56 AM
jeff 1420 jeff 1420 is offline
Vehicle: 2006 Dodge Ram 1500 TRX4
Trim Level: TRX4
Color: Blue
jeff 1420 is on a distinguished road
Default Tow rating
How can I determine the axle ratio of a 2006 Ram 1500 QC SB 4WD 5.7L V-8? Trailer Life towing guide shows the following tow capacities:
7500lbs for a vehicle with a 3.55:1 rear
7400lbs for a vehicle with a 3.92:1 rear, and
8500lbs for a vehicle with a 3.55:1 rear
I cannot locate the build sheet if there was one. The trim level is TRX4 if that is of any help.
I need the information as I'm considering buying a travel trailer and need to know what the truck's towing capacity is.
Thanks for your help.
Old 09-25-2013, 02:30 AM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
Not to be a jerk, but generally if you are thinking about tow ratings, you probably need at least a 3/4 ton. Don't get me wrong, I can tow my 5th wheel behind my 1/2 ton, but I certainly would not recommend it. It really depends on the trailer. Look at tongue weight. then look at the GVWR, of the trailer.
For the hauling capacity, you take the GCWR and subtract the curb weight of the vehicle, and an additional 1000. That should give you a rough estimate of the haul rating of the truck. Most of the 1/2 tons can haul up to a 6000 lb trailer, but be advised, that if you are going up hills, that won't be a happy trip.
Old 09-25-2013, 12:57 PM
Trim Level: TRX4
Color: Blue
Thanks for your comments! I wanted the "official" information so that I could make an informed decision as regards a trailer.
It was suggested that I contact a Dodge dealer, provide the parts dept with the VIN and they could give me the axle ratio in the 2006 RAM. I did, and they did! Thanks Cumberland Valley Motors!!
Old 09-25-2013, 02:13 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
The quickest and most accurate way to find your tow rating is to look on your drivers door sticker, which will give you the tow rating of your truck. This is key, because the tow rating is based on a number of factors, of which gear ratio is only one of and so the info on the door sticker is based on the build of your truck. It will also give you the GVWR of your truck. If this helps, but you still want or need your gear ratio, you could ask a dealer to look it up with your vin#.
Old 09-27-2013, 09:49 PM
rt9602 rt9602 is offline
Vehicle: 2005 Ram 1500 Q cab
rt9602 is on a distinguished road
Maybe this will help...
http://www.dodge.com/towing/D/home.html
