tranny cooling design flaw..My fix... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 09-22-2013, 02:49 PM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
Default tranny cooling design flaw..My fix...
As I was checking out my truck, I noticed the tranny cooler lines were routed an inch or so in proximity from the Cat. Cats, when I tow, will get hotter than heck. Here is my cheap mod I did to keep the radiant heat away from the cooler lines:
Old 09-22-2013, 03:20 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
good stuff and good post!!!
I'm sure others will find this useful
Old 09-22-2013, 03:35 PM
Irv's Avatar
Irv Irv is offline
Vehicle: White 2013 QC 4x4 BigHorn
Trim Level: BigHorn
Rep:14
Irv is on a distinguished road
So far so good with my tranny temps but I may do something similar or use some heat reflective tape just in case it does get hotter than normal sometime?
Thanks for the info and tip.
Old 09-22-2013, 06:52 PM
Pckrfan's Avatar
Pckrfan Pckrfan is offline
Vehicle: 2014 Ram 1500 Crew Cab
Pckrfan is on a distinguished road
If the truck is moving wouldn't the air keep the lines cool anyway? I can see it if the truck is idle for a long period of time though.
Old 09-22-2013, 09:23 PM
Rep:3347
The radiant heat would be pretty high that close to the cat. I would go even further and put some header wrap around the line.
Old 09-22-2013, 10:55 PM
Grubrunner's Avatar
Rep:3883
My thoughts precisely.
Grub out!
Old 09-23-2013, 12:15 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Can't hurt anything anyway
Be sure and share what material, part#, length, brand etc - you end up using for "no brainer" efforts for other forum members.
This is a good inexpensive mod.
Old 09-23-2013, 07:45 AM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
this stuff looks more than up to the task not free but ya could do a ton of other stuff as well on your truck
http://www.autoanything.com/exhausts...ermaflect-tape
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 09-23-2013, 08:17 AM
Grubrunner's Avatar
Rep:3883
The thing is this: it's not an area where hot radiant heat can get trapped for any prolonged periods because of the open space in and around the vicinity. While the vehicle's in motion, it's a non-issue. With the vehicle parked at idle, some heat may build up but will dissipate quickly because of no void spaces.
What the OP did will do nothing but be advantageous for the goals seeked but whether it's worth the time and money spent is, well, a matter of opinion..... and mine probably doesn't matter right about now.
Kudos for the originality on the task at hand though.
Grub out!
Old 09-23-2013, 10:41 AM
Rep:7
All of you have good points. If the vehicle were in motion, I agree, its way less of an issue. I do believe if the Cats were 1100 degrees and the space was say 1-2 inches, you would still feel radiant heat while in motion. No where near as much as the vehicle NOT being in motion. No, the heat isn't being trapped, but its still radiates. If I even saved 5 degrees, it was a free fix because I had the "cool tube" laying around from my race car. Another thing I did is put the cool tube on my exposed air conditioner tubes. If you notice under your hood, they run right behind the cooling fan/radiator. Why would we want the heat under the hood warming those lines?? Well I covered them too and my AC is ice cold. I can honestly say I'm not sure how much of a difference it made, but can it hurt?? Here in Arizona, the heat can be brutal......And the last heat related mod I did was to get the standard black honeycomb grill. This grill flows air straight through. My sport grill was designed different and I don't see how it could flow as much due to the angle of the fins. The next heat related mod I will be doing will be an engine oil cooler. I am a few months out, but when you see this pic, you will understand. (study it close) I was towing a few hundred less than 7K in an enclosed car hauler with heavy winds. Other than burning a full tank in less than 100 miles, I had no issues.
