Old 09-25-2013, 08:07 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Originally Posted by Red-Stripe View Post
I'm glad I saw you post this same explanation as you did last year when you explained why the TQ isn't allowed to lock up for some miles in winter. it's been bugging me to ask and clarify you saying "it's more efficient". Maybe you mean to say "it shifts better"?
What doesn't make sense to me, is that 100% of transmission losses convert to heat energy, and nothing else (unless there is noise energy), so a cold "inefficient" tranny will self heat from slippage. Why use precious needed heat( for engine efficiency) from a cold engine, or slip a TQ? Seems like you are just stealing needed energy from one area to feed another. I know my mileage suffers in the winter when the TQ doesn't lock, which makes the engine run faster turning the un-needed mechanical fan faster etc...
The main temperature-related factor is the transmission fluid viscosity. The trans fluid is thinner at higher temps. So the trans efficiency is higher (at higher temps) because the fluid is easier to pump and move (like squeezing it out of the gear teeth as they mesh).
With government standards mandating higher and higher fuel economy (why is it any of the government's business how much fuel economy my vehicle gets?!?), manufacturers are being forced to do lots of "unnatural" things to meet the standards. Like making your transmission run at 180F instead of 130F. This will actually reduce the life of your transmission (cooler is better for longevity), but your friends in the government care more about fighting "global warming" than they do about how long your vehicle lasts (or how much it costs, or how well it performs).
Old 09-25-2013, 04:55 PM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
I'm in the old MTBE belt. We loose 1-1/2mpg just from the latest mandated state of the art "winter blend" fuel".
TransEngineer: Wish you could give me a tip on how to get the converter to lock up as normal in the cold.
I'll gladly conduct and post a cold weather mpg test comparison.
Old 09-25-2013, 05:43 PM
chrisb38002's Avatar
chrisb38002 chrisb38002 is offline
Vehicle: 2013 Dodge Ram
Trim Level: R/T
Rep:86
chrisb38002 will become famous soon enough
Where do you find the "cool tube"? I have searched in google but can't find anything.
I would like to get it in red and use for some dressing up under the hood.
2013 White Ram R/T
Mods: BT Catch Can (red), Mufflex DOD24, S&B CAI, BakFlip VP Tonneau, McGaughy's 2/4 Deluxe, Spohn Adjustable Panhard, AirLift 1000, Hellwig Rear SB.
Old 09-25-2013, 06:44 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
How DARE you call them my friends!!!! And to think I thought WE were friends.
The couple times my trans has been up at 180+ I've noticed it seems like it's "slipping" when it shifts.
Sean
Old 09-26-2013, 06:36 AM
Vehicle: N/A
Rep:358
Sean, you are right! I should have said, "... but our "friends" in the government...."
Old 09-26-2013, 07:51 AM
snrusnak's Avatar
Rep:1385
I just don't understand it, I remember 10 years ago vehicles were getting significantly better fuel economy. Now with all the "improvements" they are getting the same or worse. Of course some of it has to do with the fuel as well(ethanol), yet another thing controlled by "our friends".
Sorry to get off topic...
Sean
Old 09-26-2013, 07:58 AM
Vehicle: N/A
Rep:358
Anything that the government tries to "improve" only gets worse!
And if we want to get REALLY off-topic.... just look at how they're "improving" our health care system! (Don't even get me started.. I could go on for hours...)
Old 09-28-2013, 02:16 AM
tradesman12's Avatar
tradesman12 tradesman12 is offline
Vehicle: 2013 2500 TRADESMAN CREW CAB
Trim Level: chrome appearance
tradesman12 is on a distinguished road
looking at your pic you posted... id be more worried about the oil temp if i were you, my temp didnt get over 230f pulling a 34ft 10,000lb camper at 75f in the adirondaks last week
Old 09-28-2013, 09:58 AM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
I concur with the oil temp. That's why I am working on a solution in the way of an engine oil cooler....
Old 09-28-2013, 10:13 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
In regards to the transmission, I would look at shielding the cat, drop down a piece of aluminium from the well separate of the trans lines, that way the lines dissipate heat and the cat is shielded from giving off excessive heat.
