Blue smoke, No power, and Surging - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-22-2013, 09:16 PM
83camocharger's Avatar
83camocharger 83camocharger is offline
Vehicle: 1996 Dodge Ram
83camocharger is on a distinguished road
Unhappy Blue smoke, No power, and Surging
1996 dodge ram 5.9 When truck is running in park it sets surges really bad and it smokes from burning to much gas. When climbing hills or accelerating it stalls out and sometimes die. Computer says map sensor is bad but ive put 2 new ones on it and still says its bad. Wont run with new one on it but will run with old one, just not like its suppose to. Any help is appreciated. I dont know what the code number was when i had it checked.
Old 09-23-2013, 08:53 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Did you reset the computer after replacement?
Old 09-26-2013, 11:03 PM
yes i unhooked battery and hooked it back up and reset it with a computer and cleared the codes and the map sensor code keeps coming back. Im getting the code number tommorow for further inspection
Old 09-26-2013, 11:50 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Did you try checking the codes yourself??
Blue smoke is normally oil.
White is normally coolant in the engine, or transmission fluid entering through the vacuum system.
Black is normally hydrocarbons.
Old 09-28-2013, 10:40 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
If it's black smoke, you may have a toasted o2 sensor, if it's blue, you may have an overserviced crankcase, if someone put oil in it when the truck isn't level (yeah, I did that, no mosquitoes in the 4 county area for weeks!) white smoke is always a bummer, in my opinion! A map sensor will cause a run rich deal, too check your pins to see if you have a bent one in the connector, and if there's a vacuum connection, it wouldn't hurt to make sure it's a good vacuum tube, and not burnt, cracked, disconnected, etc.
Old 09-28-2013, 11:22 PM
Rep:99
A bad plenum gasket could throw the MAP sensor off and account for the oil burning.
Old 09-30-2013, 08:01 AM
What is the plenum gasket? I had the codes checked again and they are:
P0132 - 02 circuit high voltage
P1297 - no change in map from start to run.
Ive put a new map sensor on and checked all vaccum hoses and connections. Still runs and im driving it right now. Brake pedal feels week. plenty of fluid, and theres thick oil across my new air filter.
Old 09-30-2013, 02:59 PM
melon8657 melon8657 is offline
Vehicle: 1997 Dodge Ram
Color: Brown
melon8657 is on a distinguished road
The OEM intake manifold is made of 2 pieces....the top is aluminum, the bottom is stamped steel, and the plenum gasket is in-between the two halves. Back in 2000-01 some buddies had this happen and Dodge charged them some ridiculous price like $800 to replace it.
Old 09-30-2013, 07:12 PM
Vehicle: 95
Rep:1776
Yup, sounds like the plenum gasket. If there's enough oil coming through it to stain the air filter, you can bet that that same oil is getting into the air intake system and burning in the cylinders. It's only a couple hours work and not real difficult to do. Even if you are a novice. Call it a Saturday afternoon.
Old 10-01-2013, 10:13 PM
bought a set of gaskets today that came with the plenum gasket. work in progress right now. does the plenum gasket leaking and blue smoking have anything to do with the ecm throwing a map sensor code?
blue smoke, map sensor, no power, stalls
