Decreased MPG with new K&N filter - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 09-23-2013, 12:43 AM
Zimfairy Zimfairy is offline
Vehicle: 2012 Ram 1500
Zimfairy is on a distinguished road
Default Decreased MPG with new K&N filter
Just installed a K&N 63 Series AirCharger High-Flow Intake into my Ram 1500 Hemi V8 and it seems like my Mpg has gone down instead of up - most reviews said they gained 2mpg.
Anyone experiences this?
Old 09-23-2013, 03:20 AM
Swampmoose's Avatar
Swampmoose Swampmoose is offline
Vehicle: 2012 Dodge Ram
Rep:74
Swampmoose will become famous soon enough
I have the same intake and I gained a couple after the install. Granted I love the sound so I have to keep my foot out of it to actually maintain the higher mpg
DS(Hemifever tune)/MF CB & Y/intake/DVD,2x10's,amp/debadged/McG 2/4 drop/87mm tb/180t stat/BT CC
Old 09-23-2013, 08:45 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Agree, might just be a foot issue and not a intake issue, your probably not going to see any gains, as indicated in a ton of threads about this, the factory air box is already a CAI pulling its air from the fender area, also, its very efficient, the Ram Engine needs everything it can get to produce that much horsepower and try to have a decent MPG rating. That being said, you might just be getting the "I love that sound" syndrome and when you get back to your normal foot functions you will get back to the normal MPG you had.
Old 09-23-2013, 08:59 AM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
I also agree in that most times the foot enjoys the new rumble under the hood and just can't lay off the throttle. Hahaha! But do understand that your truck has to adjust its parameters to the new aftermarket part so give it time and record your findings as in time, you will see a little gain down the road.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 09-23-2013, 10:16 AM
RPM666's Avatar
RPM666 RPM666 is offline
Vehicle: 2012 RAM 1500 LL Limited 4x4
Color: True Blue
Rep:363
RPM666 is just really niceRPM666 is just really niceRPM666 is just really niceRPM666 is just really nice
My intake plus a chip I bought off ebay gave me +45HP AND 35+ MPG's!
It's an intake. You did not get any noticeable gains and your mileage went down cause you keep putting your foot in the gas pedal to hear the new fun noise it makes.
S&B CAI // Flowmaster 50 Series HD // Bilstein 5100's @ 2.8" // Lockpick V5 // Hypertech Interceptor // Cabin filter mod // BP Polished Catch Can // TonnoPro LoRoll Cover // 4 Digit Combo Console Vault // Escort 8500 X50 Blue // GumCreek Vehicle Holster
Old 09-23-2013, 03:15 PM
picker picker is offline
Vehicle: 2005 ram
Trim Level: st
Color: mineral grey
Rep:9
picker is an unknown quantity at this point
Something else to look at......what goes in must come out. Slide under your truck and look at that stock muffler, BIG purple and blue hot spot in middle? I know dual express trucks have way to much back pressure, get rid of that stock muffler you'll be amazed how much better it runs we changed both our trucks gained a little over three MPG even service MGR in local dealership swapped his after driving this. Engine is basically a air pump, intake is the funnel putting more in won't help if it can't get out the back.
Old 09-23-2013, 05:13 PM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
Not surprised at all. MPG is achieved at 1,200-1,800 rpm's. At those RPM's the stock system is oversized and there is NO restriction with a clean filter. Then factor in when it drops to 4 cylinders at those Rpm's and you have less air flow than a squirrel fart.
Old 09-23-2013, 09:52 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
^^^^^^^^^^^^^^^+1^^^^^^^^^^^^^^^^^^^^^^^
...and that BIG HUGE INSIDE VOLUME MUFFLER......is no restriction either.........
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-23-2013, 10:05 PM
roo roo is offline
Vehicle: 2013Express,2014 Charger R/T
Rep:44
roo is on a distinguished road
Do you really have less air flow, part of the gains from switching from 8 to 4 is to lower pumping losses by opening the throttle up plate further. I do agree that the stock setup has more than enough flow for part throttle operation and more than likely WOT operation also. The RAM air box is pretty nice as is.
Old 09-24-2013, 04:35 PM
Vehicle: 2012 ram
Rep:117
The reduction in overall air mass flowing will be proportionate to the increase in efficiency, since the computer maintains the fuel/air ratio. If the MDS increase your mileage ( if ), then you have consumed less gas and air.
The small technical negative that offsets this regarding an intake/filter is that when in MDS mode the slightly reduced air mass is now required to be drawn in by 4 widely spaced pulses of air mass acceleration/deceleration instead of a closely spaced 8 vacuum event which normally gives a smother slower overall airflow.
