Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Place your Ad Here!
Old 09-23-2013, 09:06 AM
DatacomGuy DatacomGuy is offline
Vehicle: 2013 Dodge Ram
Color: Mineral Gray
DatacomGuy is on a distinguished road
Default Will this budget air system work?
Looking to setup air horns, but on the cheap as the kids online for $300+ are a tad ridiculous.
5 Gallon tank:
http://www.harborfreight.com/5-gallo...ank-69716.html
12v Compressor:
http://www.harborfreight.com/12-volt...9284-8788.html
Plus horns, accessories, etc. Looking mostly for input on the tank/compressor setup. Welcome any suggestions..! Don't have a lot of exposure and experience with air setups, so i could be completely wrong here.
2013 1500 CC | Mineral Gray | Hemi 5.7 | 3.55 LSD | 15% | Dip'd Badges | 4" AirBox CAI | Cut Antenna
Old 09-28-2013, 11:12 PM
Color: Mineral Gray
Bump to the top..
Old 09-29-2013, 12:55 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Yeah, it'll work. But where are you going to mount the tank and compressor? That tank is pretty bulky. And you have to figure out how you are going to power the compressor.
Old 09-29-2013, 01:37 AM
The Hemster's Avatar
The Hemster The Hemster is offline
Vehicle: 2013 Dodge Ram Express
Color: Mineral Gray Metallic
Rep:69
The Hemster will become famous soon enough
I guess I gotta be the guy to object here and say I don't recommend installing one of these. Unless your goal is to scare someone bad enough to cause them to crash. I can't see any other reason to go to that trouble.
Old 09-29-2013, 01:54 AM
Rep:2968
You make a good point, Hemster. I've been next to one of these a few times when they hit it and I had to change my underwear. Scared the shit outta me.
Old 09-29-2013, 02:06 AM
Planert360 Planert360 is offline
Vehicle: 2013 Ram
Color: Cherry Red
Rep:54
Planert360 will become famous soon enough
As a truck driver I can respect a nice air horn, and I use mine all the time (In the semi). HOWEVER. for the cost of it, your better off find a little electric air horn. The kind that has the horn and compressor together, easier to mount and maintain, and usually can be had for under $100.
Look up the Wolo 415 or the wolo 125. Both could be had for under $80 online, both claim 116+ db (415 is 120 db). Never used these exact ones, but I have used a few Wolos in the past and there decent for the money.
Old 09-29-2013, 02:20 AM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
If your plan is to use the same type of air horns for a big rig, you would need a compressor and tank capable of at least 150 psi. I am installing a 2.5 gal. tank and compressor on my truck so I will have air available when I go off road and into some very remote areas.
http://www.viaircorp.com/Parts/2_5gallon.html
http://www.viaircorp.com/280C.html
Mods: Too many to list
Old 10-01-2013, 08:42 AM
Color: Mineral Gray
I think i found a kit on ebay im going to go with.. I didnt want to spend $500, so thats why i was piecing together the Harbor Freight kit. However, found one one ebay for $250, so i'll probably go that route.
Old 10-01-2013, 08:57 AM
mrolow's Avatar
Rep:132
How about some pictures when you get it done?
Old 10-01-2013, 09:12 AM
Color: Mineral Gray
Definitely.. I have one or two priorities over this, but its high on the list.
I'll document whole thing once i get it.
