Old 09-20-2013, 10:35 PM
Silversport74's Avatar
Silversport74 Silversport74 is offline
Silversport74 is on a distinguished road
Default Bluetooth phone issues - full volume
Has anyone else had recent troubles with phone calls on their uconnect 8.4a? Since the last update every time I make or receive a call, and no matter if my music volume was 2 or 30, the call volume goes to 35???? I can't figure it out. Hope someone has and lets me know.
Old 09-20-2013, 10:46 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
No issues here like that, in fact that's the first I've heard of that issue. Does it just automatically go to 32 regardless of what you had the call volume at when you hung up on the last call?
Big Red my old 2011 Sport
Old 09-21-2013, 12:16 AM
Okieram's Avatar
Okieram Okieram is offline
Vehicle: 2013 Ram Sport
Color: Flame red
Rep:134
Okieram will become famous soon enoughOkieram will become famous soon enough
If I remember right you can adjust the background volume such as navigation and phone call volume separate. Music will play at whatever level you have it at and when a call comes in or the NAV has something to say it will over ride your music volume to whatever you have it set to.
2013 RAM Sport, flame red, CC, 4x4, 5.7 Hemi, 8 speed
Old 09-21-2013, 12:30 AM
KJ48 KJ48 is offline
Vehicle: 2014 1500 Ram QC
Color: Blue Streak pearl
Rep:122
KJ48 will become famous soon enoughKJ48 will become famous soon enough
Delete and re-pair the phone if you havent tried that already. Sometimes its gets a little wacky after an update.
Old 09-21-2013, 02:25 AM
Rep:2657
just look around in the MENU
you will find the volume settings for each & every thing, phone calls, navigation, messaging
it sometimes takes some experimenting
Old 09-22-2013, 02:09 PM
cpogut78 cpogut78 is offline
Vehicle: 2013 Dodge Ram 2500HD
cpogut78 is on a distinguished road
I am so glad to hear that I wasn't the only one dealing with the fact that my truck thinks Im deaf and need my calls received at full volume. Thanks to the replies from all, I am going to play around with the volume settings and see if that fixes it. Thanks.
Old 09-22-2013, 04:25 PM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
I know exactly what your talking about. I had the same issue. It finally was corrected when the dealership installed the replacement radio. The replacement radio is running version 13.31.06.
Old 09-22-2013, 06:14 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
Keep in mind that the radio volume control is separate for each source (Nav, Phone, AM, FM, Sat, Media). I found this out when my Wife turned my volume down when my GPS was talking while she was talking on her phone (whenever 2 women are talking at the same time the stronger one will dominate). When my radio came back on it was at my last listening volume. I didn't find out until I started wondering why my GPS quit telling me where to go. There are some places to set some volume controls. I know for sure there is a separate one for Nav under settings. The thing is though, as soon as you change the volume of the Nav with the dial, it changes it in the settings. It's possible that your phone was in the process of sending media or phone conversation to the radio when the volume was turned up. If that were the case though, as soon as you turned it down while your phone was transmitting it should have stuck. I just wish the volume of the Parksense could be adjusted through the radio like my Mother's 2013 Dodge Journey does. On her Journey, you can turn the volume down to a more reasonable level and it stays. At least Dodge lowered the volume a bit from my initial software version, but I still wish I could control it.
Old 09-22-2013, 09:25 PM
I thnk I fixed mine. I re paired my phone and that didn't work. I change the nav volume and that didn't wor either. So I made a call and turned it to 20 before it started dialling. The call stayed at 20. Tried it again without touching the volume and it must have saved. Whew. My ears have thanked me.
Old 09-23-2013, 10:34 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
IMO the best solution is to do a hard reset. I have had similar uconnect issues with mine and done this and it went back to normal again. (only downside is having to reprogram your channels and re-pair your phone)
Steps to reset:
1) Hold both the heat and cold buttons (arrows) simultaneously for about 5 seconds, a new "developer" screen should appear.
2) Scroll down to "reset to factory settings" and press.
3) you should get an "are you sure screen" just press yes
4) Give it about 30 sec or so to boot back up and it should be good to go again.
Hope this trick works for you like it did for me, good luck!
Hellwig Sway Bar, Green filter, Borla XR-1, Line-X, Bak RollX, JBA TCC Shorty's, Raptor 4" nerf, Hunter Bull Bar, 20" Cree LB, Moroso Catch Can, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, Bak Box 2, Trinity T1000
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
