Old 09-23-2013, 09:40 AM
leeadrian3841 leeadrian3841 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT Quad Cab
leeadrian3841 is on a distinguished road
Default 2005 Ram 1500 tailgate assist install help.
Hi,
Trying to install Dee-Zee tailgate assist and tried to take the tailgate cable bolt off and it is impossible to take that off. Any tricks or method?
Old 09-23-2013, 10:08 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Breaker bar with a torx socket will work. Mine was nasty and it's brand new!
Big Red my old 2011 Sport
Asur Asur is offline
Vehicle: .
Rep:4373
its probably rusted on the inside, put some PB blaster penetrating oil on it and let it sit a while, do that a few times, you might might be able to access the area also via the tail light area, then get yourself a good strong bar and slowly try to loosen it, JMO
Old 09-23-2013, 10:16 AM
Thank you for the input. I was concerned that it might have welded on since I could not get it break! I will try penetrating oil and breaker bar as well.
Thanks alot.
