Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-24-2013, 02:16 AM
HeMi BosS HeMi BosS is online now
Vehicle: 13 Hemi Ram Sport
HeMi BosS is on a distinguished road
my tire store, told me to rotate at 10,000 miles
16093.44 kilometers, i believe is the correct conversion
10,000 kilometer = 6,213.7 miles
you will get varied answers to the oil & filter change times
when you go to synthetic oil, it depends on when YOU want to do it
i finally switched over when i had 42,000 miles on the Ram
some people do it after they reach around 3,000 miles
I change my oil & filter at 5,000 miles & i take my own oil & filter to the dealership to get it done, i buy the oil at the local Walmart, 5 quart jugs are $25 USD + tax, for my choice of motor oil, Mobile One synthetic, i buy a good quality oil filter, in my case that is a WIX product
others will use different mileages, like 8,000, etc.
my air filter gets checked for cleanliness about every 10,000 miles, i have found that mine lasts around 20,000 - 25,000 miles
im going to get my oil changed tommorow ,, but i called my local dodge dealer and spoke to the service center,, he said if im not really hauling anything i should stick to regular motor oil until 30/40xxx kms. Then switch to synthetic,, and also he said i could switch now aswell but it might leak.
so should i use synthetic tommorow or regular motor oil ?
if i use synthetic or regular oil what intervals should i do oil changes ?
last question is i called a local oil change place and they'll do a oil change for $36 with tire rotation and a bunch of other stuff like check brakes, fluid levels ect... so should i rotate tires now or just wait..
thanks for the help.
Old 09-24-2013, 03:07 AM
Rep:2625
I don't know anything about your independent oil change places up there in the North
but down here, i would not trust them to check anything on my vehicles
i took my last vehicle to one called JIFFY LUBE down here
i told them that i wanted a wanted a certain brand of oil & i be darned if they didn't use their own company brand of oil
i watched them do it, because i don't sit in their office watching tv, i stand right outside of their bay doors
i take my own oil & oil filter to the Dodge dealership & i pay them about $17 to change the stuff that i bring in
mostly because i know that they will do it right & know what else to check on the Rams.
that also insures that they have a permanent record of everything that was ever done to the Ram & they would have a very tough time proving that i did something that could VOID the Warranty
Old 09-24-2013, 03:16 AM
The Hemster's Avatar
The Hemster The Hemster is offline
Vehicle: 2013 Dodge Ram Express
Color: Mineral Gray Metallic
Rep:69
The Hemster will become famous soon enough
What the heck is KMS? 'Merica!
Old 09-24-2013, 07:58 AM
tattwo98 tattwo98 is offline
Color: Deep Cherry Red
Rep:62
tattwo98 will become famous soon enough
FYI Rebate for Mobil 1
Old 09-24-2013, 10:16 PM
ferret ferret is offline
Vehicle: 2013 dodge ram 1500
ferret is on a distinguished road
Follow your owners manual. It states,change oil when system indicates to. It also notes under no circumstance should you exceed 16,000km or 1year which ever comes first. I just did my first oil change. Truck is 4 months old and when system indicated oil change required odometer read 15,458km. Don't fret, as long as you follow owners manual and your truck you'll be fine.
Old 09-25-2013, 07:23 AM
dparise's Avatar
dparise dparise is offline
Trim Level: ST w/SXT pkg
Color: Black Gold Metalic
dparise is on a distinguished road
Chrysler employs a lot of very smart, well paid people who's job it is to come up with the maintenance intervals. They spend a lot of money and time making sure they have those right. Follow the book, I'm not going to get into my usual rant, but lets just say, I have 2 points, firstly, when's the last time you heard of someone spinning a bearing? Burning a valve? needing a ring job?
Secondly, I can guarantee that all these people telling you that they do their oil changes at 1/2 or less than recommended intervals don't do their other maintenance at 1/2 intervals.(shocks, struts, trans fluid, coolant, etc...)
Old 09-27-2013, 07:25 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
Well said. I'm going to use my hard earned money for a better cause. If Ram is happy with it so am I.
Aepowell Sherman,TX.
Old 09-27-2013, 04:45 PM
Tcon Tcon is offline
Vehicle: 2013 Ram 1500 QC 4x4 Sport
Rep:49
Tcon is on a distinguished road
Just my 2 cents:
The owners manual does state that the evic will let you know when to change your oil but don't let it exceed 16,000km.
I think I changed out my factory oil from conventional to synthetic at the 500Km mark (or was it 250km). The reason for that was to get that conventional oil out along with any factory debris.
The negative side effects of changing to synthetic early is a myth. Most performance engines come with synthetic from the factory.
My last truck (2003 Hemi) had synthetic since the 250Km mark and is still going strong at 250,000KM (never a single repair either).
5.7L/8 Spd/3.92/Air Ride - Whited Out Badges - S&B CAI, 87MM TB, BT Catch Can, Magnaflow 22", Magnaflow Y Pipe, Weathertech Vent Visors, White 3" Stubby Antenna, DeeZee Tailgate Assist, Bak Flip G2
