Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 09-24-2013, 10:15 AM
newramkid newramkid is offline
Vehicle: 2014 1500
Trim Level: Limited
Color: GCM
Rep:17
newramkid is on a distinguished road
Default Anyone purchase a BAKFlip yet for 2014's?
Their website only shows up to 2013 model year for 1500's.
I sent them an email this morning. I'll post their reply when I hear back.
J
Old 09-24-2013, 11:49 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
The box size hasn't changed from around 2003 - present Rams. Any cover that is listed to fit a 2013 will fit a 2014 as well.
Old 09-24-2013, 12:28 PM
ramit355's Avatar
ramit355 ramit355 is offline
Vehicle: 2014 1500 4x4 CC Laramie 392
Trim Level: Laramie Crew Cab
Rep:28
ramit355 is on a distinguished road
I can say the box has a taper to it after 2009 models . Any flip that would run inside of box with a rail system such as roll n lock or pace Edward will not fit prior to 2010 or. 2011
Old 09-24-2013, 02:27 PM
Rep:2032
If that were true why does Bakflip sell the same cover for 2002 through 2013 trucks? If it didn't fit I'm pretty sure they would have figured it out by now.
http://www.bakfliptonneaucover.com/dodge?b=1
Old 09-24-2013, 03:22 PM
gwilburn's Avatar
gwilburn gwilburn is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Color: Maximum Steel Metallic
Rep:108
gwilburn will become famous soon enoughgwilburn will become famous soon enough
I'm picking up my 2014 Crew Cab tonight... planning on installing the F1 from my 2005 Quad Cab on it (both have 6'4" bed)... part numbers on website are exactly the same.
Old 09-24-2013, 05:30 PM
ramit355's Avatar
Rep:28
Because it is true the bed TAPERS!! If you have any Covers that mount on rails INSIDE the bed they tapered the inside of the box in 2009 or 2010 like I said. The one you just sent mounts on TOP of the bed.The cover will fit but it will cover less of the bed rail cap near the cab then cover more at rear of tail gate. If any are on rails inside it will not work. Just offered to try and save some folks time and money I have no reason to post shit
Old 09-24-2013, 05:47 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
hoping the one I ordered for my 2014 with ramboxes fits
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Rep:2032
K buddy.... do some research before you go posting stuff like this. If you knew anything about how a Bakflip cover was installed you'd know that the tonneau cover rails are mounted on the inside of the bed rails. Yes the outside of the bed tapers, but that doesn't mean the inside does. It is still square. If it wasn't the tonneau cover I have on my truck wouldn't fit, but it fits pretty damn good if you ask me. So yes you see more of the bed rail up at the front of the box compared to the back but that has nothing to do with how the Bakflip tonneau cover sits or seals on the bed.
So I guess you're right, you have no reason to post shit because you haven't done your research and you don't know what you're talking about.
As long as you ordered model number 26207RB it will fit no problem. Bakflips website even shows up to 2014 trucks on it for that cover now.
Old 09-24-2013, 06:25 PM
Vehicle: 2014 1500
Trim Level: Limited
Color: GCM
Rep:17
Yup
Brandon is correct about availability. Spoke with one of their CS reps, she says they are literally in the process of adding 2014 covers and vehicle coverage. Should be updated fully this week.
Also-Just because you don't see your model-year/bed-cover they are probably in stock.....just a little behind in the site being updated
Ordering one this week.....lol now to decide on which one :P
thanks for the help folks-
J
Old 09-27-2013, 09:23 AM
gwilburn's Avatar
Rep:108
For all of you wondering...
Last night I installed my Bakflip F1 on my 2014 Ram 1500 Crew 6'4". I had this cover on my 2005 Ram 1500 Quad Cab.
It fit perfectly once I removed the rail spacers that were required for my 2005 (didn't have a bedliner or railcaps like my 2014).
