Old 09-24-2013, 03:53 PM
ricroc ricroc is offline
Vehicle: 2013 Dodge Ram 1500 2wd
Trim Level: 1500 Express
Color: Metallic Grey
ricroc is on a distinguished road
Default Tire Rubbing Question
Quick question guys, will a 35x12.5x20 tire rub on a 2wd 1500 with a 4inch CST lift. I have 20x9 wheels with 1mm offset?
Old 09-24-2013, 04:01 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I think you should be okay. with 4" lift, and a close to 0 offset. you should be fine. Might end up depending on which brand tires. Some run 13.5" wide true, and some run smaller than 12.5"
you should be golden
Old 09-24-2013, 04:02 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
You'll be fine. Shouldn't rub at all!
