Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Dodge Ram Decals
Old 09-24-2013, 06:16 PM
Shooter 21 Shooter 21 is offline
Color: Black Gold
Shooter 21 is on a distinguished road
Default Heat has a mind of its own
Anybody having problems with there climate control. Initially dealer replaced heater control valve to no avail. Then replaced heater core which was blocked, however the heat still does not always want to work. Normally when you first start truck you get heat but change any settings and you stop getting hot air. A/C works fine. Waiting to see what Ram has to say as dealer has no idea.
Old 09-24-2013, 10:29 PM
S.FLRAM
Back in the day, one would look at a vacuum issue, however on these newer vehicles you have to have $15K worth of electronics to diagnosis a burnt taillight. Good luck!
