Tire rub on left front - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 09-25-2013, 09:45 AM
gwilburn's Avatar
gwilburn gwilburn is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Color: Maximum Steel Metallic
Rep:119
gwilburn will become famous soon enoughgwilburn will become famous soon enough
Default Tire rub on left front
When backing out of my driveway to the left (turning wheel left), my left front tire rubs on the wheel well liner. I do have the air suspension - left at factory settings (just picked it up last night).
Anyone else see this?
Old 09-25-2013, 01:17 PM
exilepa exilepa is offline
Vehicle: 2014 Longorn 1500
Trim Level: Longhorn
Rep:15
exilepa is on a distinguished road
Same issue here, haven't really looked to see what's causing it. I'm guessing it's probably something to do with the air ride.
Old 09-25-2013, 02:39 PM
KnuckleHead's Avatar
KnuckleHead KnuckleHead is offline
Color: Black/Silver Two Tone
Rep:89
KnuckleHead will become famous soon enough
I don't have mine yet, but I have seen posts that they will rub when fully turning to the left in entry/exit mode. Surprising to me that they would do this from the factory, but that is what I hear...
2014 RAM 1500 Laramie...Ordered 8/3/13, Built 9/10/13, Arrived 10/1/13.
Old 09-25-2013, 04:00 PM
gwilburn's Avatar
Rep:119
This isn't in entry/exit mode... it's at the end of my 120 foot driveway (yes, I back out). There is a square detent in the left inner fender behind the tire. The tire is rubbing here.
I looked underneath & behind the liner... totally astounded at the exposed wires/electrical connections just behind the wheel liner. With the winters we have, that is going to see a lot of abuse.
Old 09-25-2013, 11:04 PM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:311
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
Very common with the air-suspension. Mine did it in the entry position. Once I installed taller tires, it did it in the normal position. I fixed mine by taking a heat gun to the large bump and pushed it in till the plastic hardened back up. It isn't as pretty as it once was but at least it doesn't rub anymore in any position.
Old 09-26-2013, 01:15 PM
gwilburn's Avatar
Rep:119
Really poor design. But I'm not in the entry position and I have stock tires.
Old 10-21-2013, 12:53 PM
Boogys1500's Avatar
Boogys1500 Boogys1500 is offline
Vehicle: 2014 Ram 1500 Sport
Rep:16
Boogys1500 is on a distinguished road
same thing on my 2014 ram 1500 sport with air suspension in normal mode. I went and just pushed the plastic in and problem went away. It sounded gross
14 Ram 1500 CC Sport 3.92 8Speed, Air Suspension, BFGoodrich KO2 275/60/R20, Corsa Exhaust, Hemi Fever DCX 91oct Tune, K&N Intake, 87MM Moes TB
Old 10-21-2013, 01:35 PM
2014LHLTD's Avatar
2014LHLTD 2014LHLTD is offline
Vehicle: 2014 Ram Limited TrueBlue
Trim Level: Limited
Color: True Blue
2014LHLTD is on a distinguished road
That simply sucks!!!
Take it back to the dealer and get them to look at it......
They hardly going to say it's working as intended......or would they....
Cheers
Old 10-21-2013, 02:49 PM
gwilburn's Avatar
Rep:119
Dealer fixed mine... along with aligning the entire truck cab and rear bumper... No kidding, it was all off.
Noticed the bumper off - thought the bed was on crooked. After inspection by the dealer, the cab was off too.
Looks like they moved the cab back about 1" and turned the bed counterclockwise? They still had to shim the bumper supports.
Old 10-21-2013, 10:26 PM
mattp160 mattp160 is offline
Vehicle: 2016 Ram 2500 Laramie Limited
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
mattp160 is on a distinguished road
I have air suspension on mine as well, I'm not noticing anything rubbing on mine and I have a dip at the end of my driveway.
