Old 09-25-2013, 08:01 PM
hesm70 hesm70 is offline
Trim Level: SLT w/Big Horn
Color: Deep Cherry Red
hesm70 is on a distinguished road
Default Uconnect 5.0"
So my first issue popped up. The radio screen on my Uconnect 5.0" did not turn on after leaving work. The radio worked for the most part. Turned on and off but only the volume worked and it was stuck on the last radio station I was listening to.
I called the dealer and the solution, wait for it. Yes unplug it! Well, disconnect the ground to reset it. Low and behold it worked. Anyone else had this issue? I have had the truck a month and a half.
Old 09-25-2013, 10:45 PM
springram springram is offline
Vehicle: 2013 Ram 1500 Quad Cab
Trim Level: SLT 4x4
springram is on a distinguished road
Not the same, but an interesting situation.
SXM channel 3247, which doesn't exist, yet it was playing The Highway. All the screen showed was channel 3247. Changed to FM and back, the same thing. Browse XM, all genres empty. All presets empty. Manually rotate the tuner, still The Highway.
After work I started the truck and everything was back to normal. No idea.
Old 09-26-2013, 06:36 AM
bsmith79 bsmith79 is offline
Color: Gray
bsmith79 is on a distinguished road
I had the EXACT same thing happen. Drove from work, no screen and only the last station it was on would play, stopped at walmart, and when I came out, it was fine and I haven't had any trouble since.
Old 09-26-2013, 06:48 AM
dparise's Avatar
dparise dparise is offline
Trim Level: ST w/SXT pkg
Color: Black Gold Metalic
dparise is on a distinguished road
I had the exact same issue with my 3.0 radio. It was like that all day, running errands and whatnot. I stopped by the dealer to make an appointment to have it looked at and literally as I got back in my truck to leave the dealer it started working, and has never done it since.
Old 09-26-2013, 07:51 PM
Jarhead57's Avatar
Jarhead57 Jarhead57 is offline
Senior Member
Trim Level: Express w/options
Color: Mineral Gray Metallic
Rep:36
Jarhead57 is on a distinguished road
Same here with the strange channel, went away next time I used the radio and has never happened again.
Dee Zee Tailgate Assist - Cabin filter mod - BT Catch can - SnugTop F2 snuglid - Weathertech mats, mudflaps and vent visors - Spyder® Led Tails - All Led interior, exterior, Led Drl's - Bilstein's - Airlift 1000 - Whistler 1200w inverter - Debadged - Kicker speakers - TYC black projectors - HID 35w-5000k heads and fogs
