Old 09-26-2013, 03:26 PM
MurderedOne87's Avatar
MurderedOne87 MurderedOne87 is offline
Vehicle: 2013 Ram 1500 Black Edition
Trim Level: Tradesman/Express
Color: All Black
Rep:70
MurderedOne87 will become famous soon enough
Default What subs and box in QUAD cab Already have a kicker ZX1000.1.
Hey guys looking for suggestions on what subs and box to go with in my 2013 Ram Quad cab.
I am very used to loud deeeeeppp bas since i have had 2 cvx 12's_in my tundra crew max (tons of room behind the seats) then i went to a 13' Charger and has a ported probox with a 1200 watt RMS Rockford Fosgate t2d2-12.
I am accustomed to loud booming bass. Now with that said i am soon realing the fact that i ave to have my back seat and i would like the enclosure to be under the rear seat.
I already have a kicker ZX1000.1 which produces a true 1000 watts-ish at 2 ohms.
so i plan on installing 2 10's or 2 12's DVC 2 ohms.. i am just unsure on which ones match up well with a sealed enclosure that can sustain that amount of watts with out blowing.
help.
Old 09-26-2013, 04:47 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2011 Ram Express
Rep:92
Graygoose will become famous soon enough
If you can find the Kicker Solo Classic, do the 10", they like small sealed, .66 per driver. Stick with 10's, you'll find more apps than a 12". Even the CVX 10" would work.
2015 Crew Cab Bighorn
Old 09-26-2013, 05:11 PM
Color: All Black
Rep:70
This is the set up i am looking at
Dual 10 box
http://www.ebay.com/itm/350860512944
2 Kicker 10 2 ohms compRT
http://www.crutchfield.com/p_2061CVR...er-reviews-tab
Running with the kicker ZX1000.1 @ 2 ohms.
The amp is a little higher than the subs are rated but the box offers 1. cubic foot of air space and the cvr's ask for a minimum of .8
I wish i could go with the CVX's but the obx only offers 6" of mounting depth. The CVX ask for 8".
Last edited by MurderedOne87; 09-26-2013 at 05:39 PM. Reason: CHANGED MY MIND ON THE SUBS
Old 09-26-2013, 09:37 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
Get off Ebay, you will blow those boxes apart. If you want loud deep bass then go with the Netaudio box if he can make you one, or go with the Fox Box.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 09-26-2013, 10:47 PM
Color: All Black
Rep:70
My plan for the temporary is to waste the $65 bucks on the cheap ebay box and try it out for a bit until I can rake the cash together for a the $400 net audio box.
I sae he has like a 2 month lead time anyhoo.. so might as well have something in until the slower season.
Old 09-26-2013, 10:49 PM
Color: All Black
Rep:70
Also
I went ahead and purchased the 2 kicker comprt 10'z part number 40CWRT102
The specs screamed efficency and should match up well with the shallow boxes we have to have.
Old 09-27-2013, 01:08 AM
hemi07's Avatar
hemi07 hemi07 is offline
Vehicle: 2010 ram
Color: blue
Rep:12
hemi07 is on a distinguished road
I got one 12" clarion single box under the rear passanger seat jl audio 1700. IT SOUNDS GOOD
Old 09-27-2013, 10:54 AM
Graygoose's Avatar
Rep:92
http://www.proboxrocks.com/products/...10/index.shtml
Would have been perfect with the CVX 10's
Old 09-27-2013, 11:42 AM
Color: All Black
Rep:70
I am only about 15 miles from the pro box factory.. I have talked to the head engineer many times out there..
If i found out the vminnovations box is trash.. im going to take the loss and look into the pro box, fox box or net audio.
I am really excited to check out the new kicker comp RT. If the specs are right it may be the best shallow sub out there... I hope so!
Old 09-27-2013, 03:15 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Ported fox box with Alpine type R 12s. Biggest boom with keeping the rear seat.
