Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-27-2013, 08:57 AM
Farmer1 Farmer1 is offline
Vehicle: 2013 dodge ram Big Horn
Farmer1 is on a distinguished road
Default Oil Change indicator reset
Just had my 1st oil change at the dealer . Oil life gauge was at 50 % --- can not find information on how to reset back to 100 percent . Can any one help ??
Old 09-27-2013, 09:26 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Easy to do, turn your ignition on without starting the motor and push the accelerator pedal to the floor 3-times in succession and your done.
Old 09-27-2013, 09:53 AM
Grubrunner's Avatar
Rep:3883
Just like it says in the User's Manual....
Cheers H1
Grub out!
Old 09-27-2013, 11:24 AM
Thanks could not seem to find it in my owners manual . Must be old age ! Again thanks for the info .
Old 09-27-2013, 01:22 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:90
Bushmaster will become famous soon enough
If the dealer did it, why didn't they reset it.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 09-27-2013, 02:56 PM
Vehicle: A Truck
Rep:2559
Probably forgot, easy to do... change oil and move on to the next.
Old 10-01-2013, 07:44 PM
Dubble Dubble is offline
Dubble is on a distinguished road
Should I change oil every 5000 km's, or 3000 miles for the americans, or should I go off the Oil Life Monitoring system?
Old 10-01-2013, 07:49 PM
jrtz80's Avatar
jrtz80 jrtz80 is offline
Vehicle: 2012 Dodge Ram
Color: Tequila Sunrise
Rep:51
jrtz80 will become famous soon enough
The monitering system is supposed to take into account the way you drive and adjust accordingly but I don't know if it actually works...
180 Tstat, Solo CB, Moes 85 TB, S&B CAI, Catchcan, Hemifever, Airlift, Kicker audio, SmartStart.
Old 10-01-2013, 08:14 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
We just had this debate in another thread but I'll recap
If you read through the manual it doesn't really stipulate (other than not going over 10k without a change) what the frequency should be. Talking with my dealership at my last oil change a couple of weeks ago the service writer said follow the truck monitoring system as it takes into account all the factors like idle time, drive time, towing...you get the idea.
I'm an ex-mechanic and I still run by the dated rules of every 5000km on fossil oil and every 10k on synthetic. However with todays advances in motor oil the old 5 and 10 are actually outdated and overkill.
So I guess the simplified answer is to follow the on board monitoring system but never go over 10k without changing the oil.
Big Red my old 2011 Sport
Old 09-23-2014, 07:18 PM
frankieflush frankieflush is offline
Vehicle: 2013 dodge ram 1500 4x4 5.7L
Trim Level: sport
frankieflush is on a distinguished road
I just had my oil changed at the dealership and they didn't rest the oil life meter. I did the turn the key and press the accelerator 3 times but it won't rested rest. Turn to on press accelerator x3 then turn off. That's what it says to do no luck any ideas?
