Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 09-27-2013, 10:19 AM
mikejones mikejones is offline
Vehicle: 2005 Ram Laramie
mikejones is on a distinguished road
Default Tire shoulder wearing fast
Hi
I have a tire wear problem. Truck is a'05 1500 4x4 Laramie.
The drivers side front tire wears on the exterior shoulder area. I had a spare tire so I replaced the old one and in a matter of weeks, the tire was completely wore to the belt. I don't corner hard of anything.
When driving at slow speeds, I cannot notice any steering pull. If I drive at speeds greater than 40 mph, the steering pulls slightly to the right so I "correct" it by constantly steering slightly to the left.
When driving over bumps, there's some knocking coming from the drivers side front end.
I know I should get it aligned but first I'd like to know what's causing this. Then I'll repair it and I'll buy new tires.
What could be the culprit? Ball joint? Control arm bushings?
What's the best way to find out myself?
Do I need special tools/pullers/anything else to replace front end parts on the ram? Is it an easy job?
Thanks!
Old 09-27-2013, 10:37 AM
Grubrunner's Avatar
Rep:3883
You have an alignment problem.
Grub out!
Old 09-27-2013, 01:07 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
If you have knocking coming from the front end over bumps it could definitely be a worn out ball joint. I would have those checked before anything because they would be throwing your alignment out which is why you're getting the tire wear.
So check the ball joints, if needed replace them, then have a front end alignment done. That should solve your problem.
Old 09-27-2013, 01:31 PM
I'll check the ball joints. Are they a pain to replace or you need to replace the whole arm? I never did it on a ram.
I'll definitely check the ball joints, then throw a leveling kit then the alignment
Old 09-27-2013, 01:34 PM
Rep:2026
They should be replaceable but you'll probably need a few specialty tools to do it.... I'm not 100% sure as I haven't done them on a Ram either. Doing a quick google search should bring up some answers though.
Old 10-10-2013, 09:15 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
I replaced my ball joints and tie rod ends on my 02, I will tell you my truck was a HUGE PITA! Now I live in NJ so I get snow/salt during winter which doesn't help. BUT a torch came in handy to losing things up. Tie rod end was easy just ball joints where pain. I'm sure though if your weather conditions are better then mine it be easy. The pita part was just getting old out, like I said torch, hammer, and I forget what tool I used. The autozone ball joint tool blows and didnt work for me.
