Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 09-27-2013, 03:56 PM
Hologram Hologram is offline
Vehicle: 1999 Dodge Ram sport 1500
Hologram is on a distinguished road
Default Can't remove plug
I have a heat tube around one of my plugs that seems to be closer near the bottom to my plug making it hard to get the plug socket on.I actually have to tap it on with a hammer but can't hardly loosen it because the socket is just binding against the tube.Any tricks to spread the tube at the bottom?Already shattered the white part of the plug and its nearly impossible to loosen this way.
Old 09-27-2013, 10:04 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Get a pair of vice grips and remove the tube.
Old 09-29-2013, 01:08 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Exactly. You can also tap the tube with a small hammer to help loosen it. They are just rolled metal pieces that are inserted and held in under mild compression. You can spray some lube to help loosen any rust of corrosion. Use high quality silicone plug wires and there's no need for those tubes. The Mopar smallblock existed for a quarter century before those stupid tubes were used.
Old 09-29-2013, 01:57 PM
Vehicle: 95
Rep:1776
Exactly...it's just a tin metal exterior roll pin. For lack of a better term.
Old 10-01-2013, 06:18 PM
Travisiwb's Avatar
Travisiwb Travisiwb is offline
Vehicle: 1998 Dodge Ram
Travisiwb is on a distinguished road
I had the same problem so I just shaved the socket end down with a grinder and it slid right in to the heat tube and got the plug out my plug also broke and I still got it put
Old 10-02-2013, 01:06 AM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
get some PB blaster and spray it in there grab a vice grip and pull out the sleeve. that should do the trick. if you want to keep them in there put a little motor oil on the outside of the socket and slide it in there it will keep it from binding up against that sleeve
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
