Old 09-27-2013, 08:09 PM
aceman aceman is offline
Vehicle: 1988 ram 100 short bed
Color: red
Rep:39
aceman is on a distinguished road
Default plastic tank repair.
i didn't know where else to post this so here it is. has any one here ever successfully repaired a plastic fuel tank by re melting/ welding the split back together using a soldering iron. thanks for any help.
Old 09-28-2013, 01:17 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Use this
http://www.itwconsumer.com/versachem...pair%20Kit-150
Old 09-28-2013, 02:33 PM
Color: red
Rep:39
that says its not for plastic tanks.
Old 09-28-2013, 02:51 PM
Vehicle: .
Rep:4373
Sorry wrong link
Old 09-28-2013, 09:59 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Either that or try JB Weld.
Old 09-29-2013, 01:31 PM
indamud's Avatar
indamud indamud is offline
Vehicle: 2013 DODGE RAM
Trim Level: SL
Color: TRUE BLUE
indamud is on a distinguished road
I built a dirtbike where I had to notch the tank and had it plastic welded.They basicly have a heatgun with a special tip that you can load a plastic rod thru,then it melts both parts together.So it can be done if you can find someone in your area.But above link looks easier.
Old 09-30-2013, 04:11 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
i have used a two part epoxy (industrial type) and got a piece of plastic that had at least 2 inches of plastic to overlap the hole i had to repair on a peterbuilt def fluid tank. after the epoxy dried and fully cured i used a heat gun to melt some softer plastic around the edges of the patch to create an extra outer seal and it has been working for the last 2 years with no problems at all.
Old 09-30-2013, 06:29 AM
Color: red
Rep:39
i got the rest of the gas ran out of the tank. i am going to start dropping the tank next weekend. then i am going to try sealing the split back together. i have already used a repair putty from napa/ permatex. but that has already started leaking after a week and it was for plastic tanks. i am thinking of trying the melting the plastic back together with a soldering iron then melting a patch over it with a sealing iron. although i might first try the stuff Asur sugested then seal with a plastic patch. the split is about 6 inches long.
Old 09-30-2013, 07:45 AM
Vehicle: .
Rep:4373
Keep us posted on how it works out, pics of before and after would be real cool, I think that the outcome good or bad would interest a few members who may end up in the same predicament. Please try and find the time to come back with your results.
